All of us who work on Hackaday.io are reading your feedback. If we don't get back to you individually, know that we read what you wrote. Thanks for taking the time to give us feedback, we really appreciate it, you help improve the site every day!
Bugs, Feature Requests, Wishlists
Maybe just editign the class in teh <pre class="hljs cs"> will work?
After trying every highlight choice, I'm now curious if I can "contribute" another choice to hackaday for highlighting Forth code?
There may be another option available to turn on if you see it here https://highlightjs.org/static/demo/
Richard, thank you. I'll do some homework and see what I can come up with for forth. The assembler would be a nice add, as I see a lot of folks posting assembly lang bits for their projects. It appears the back-end source for these is highlight.js, so I'll start there.
https://github.com/highlightjs/highlight.js/tree/master/src/languages
Are you are having trouble selecting the video? The top left button when in edit mode will toggle source, you can try deleting from there also.
Thanks. Editing the HTML directly worked. I expected a video delete button option when right clicking on the video.
@Richard Hogben I wondered if you guys could devolve some of the spam cop duties by implementing a feature where if more than say 10 long time active users (so that recent signups can't hack this) report a user as a spammer, the account gets suspended and all posts are hidden. Then an admin can take a look at without haste.
Also is it a good idea to allow Github users to login and have no barrier to posting? Maybe have to be a long time active user to be able to post to .stack?
It would be kind of nice if the .Stack were not being completely flooded to High F*ckall with inscrutable Moonspeak bot-spam right now. My "Personal Feed" unread-posts counter was in the low-middle triple digits a few minutes ago, and it's been going up rather alarmingly fast for well over an hour... this is why, and I don't exactly appreciate it.
I'm just sayin'.
...on an ironically positive note, at least the notification thing isn't spamming my email inbox about it.
To whomever came by with electronic mop and bucket: THANK YOU.
...also: while I realize it's something of an arms-race sort of set of circumstances, could we *please* have better anti-bot protections here? It's not like this hasn't been asked about before. It's a continuing issue, and ignoring it is a very bad solution.
It's not being ignored, and it's constantly evolving behind the scenes.
@Richard Hogben Very glad to hear it! I bet a lot of us would like to see how that happens and what affects what -- and, who knows, maybe the more network-y amongst us (not me, I can reset a router and plug in a LAN cable and that's about it!) might see something that others missed and have a useful suggestion as a result.
At the very least, having it tracked publicly would provide idiots like me ( :P ) with both a bit of entertainment and one less reason to assume, when things go all pear-shaped like that, that it's because there's nothing to stop it.
I'm probably missing something but I don't see an easy way to find the projects that I am following on one list.
Go to your own profile and tap on Following and it will give you a page of projects you are following.
Unabel to delete account when authenticating over github. Please fix.
[New user] Way back in 2012 there was talk of a "lights on" switch to change to a light theme. (https://hackaday.com/2012/11/16/the-new-template-has-arrived/) Not everyone works in a dark room where the screen is the only source of illumination. My environment is fairly bright and the site is almost unusable.
I didn't see anything in the menus or profile settings to change this, but maybe I'm missing it because I literally can't see it.
I would like to see a high contrast option, are you reading more on hackaday.com or looking for a solution on hackaday.io ?
When posting a new project on hackaday.io, the image sizes used range from square (in the "my projects" gallery), to an extremely wide aspect ratio on the project page when the browser window isn't as wide. For those of us trying to present our projects in as appealing a way as possible, it's impossible to have photos that look good both in the square and widescreen formats. Something inevitably gets cropped in a frustrating way.
From a visual design standpoint this is maddening.
Hey sorry about that, we are working towards standardizing all image aspect ratios to a more friendly 4:3 size.
I finally got an email in less than an hour so was able to verify (re: @cprossu 's post below) .
Is there not a way for a creator to delete a spam comment on their project? I reported it as inappropriate, but it seems like I should be able to at least hide it. Am I missing something?
If you reported it should be removed asap, if not PM me the comment and I can take care of it.
Thank you, it's all taken care of. I just didn't know if I was missing moderator tools. Those would be a great addition to the platform!
I am running into a problem where I cannot add members to my team. It says "Something is wrong. Please try again." no matter what I try, if I clear my cache, or if I switch browsers. Not sure what's going on here, I was directed to post here for help. https://cdn.hackaday.io/images//3805111589681866033.PNG
I'll check on this, if it ends up working for you later let me know.
Nope, still having problems. I asked him if his email was verified, he did not know, and he then attempted to verify his email manually, and it did not work.
He gave me the following info to pass along to you, as he cannot provide feedback without the Email being verified.
The email verification flow is broken. Specifically, when I resend the invite, it is taking in excess of an hour for the email to make it to my account (I've done it on two different accounts, both of which are receiving other email without issues. I've checked spam in both. The email does show up, just really really late). The result is by the time I get the email the token has expired and I can't verify. If it helps, I tried to send the invite twice this morning at ~0700 MST. The two emails arrived at 0806 and 0839. I clicked on the 0839 email about 0845 and the token was expired.
Quick update, he was finally able to verify, got it all sorted for now it seems.
Add Hack Chat (https://hackaday.io/messages/room/2369) to robots.txt disallow.
As anyone who has spent anytime in Hack Chat knows, there are frequent (multiple a day) drop ins asking for help to hack this service or that. A quick check shows multiple search results for "hacking" will give hack chat in the first page. While most regulars patiently explain this isn't what hackaday is about, preventing it in the first place would be nice.
I would go as far as to suggestion, indexing the public chats at all is probably in no ones best interest.
And now I'm getting PMs asking me to help someone hack emails. Please take @morgan's advice and discourage the perception that this is a site where you come to find hackers for hire.
The authentication with Github seems like it is completely broken, when editing account clicking on `Authorize with Github` the page navigates to the main feed and does not allow changing any of the settings.
The workaround I found was to trigger a password reset via `forgot your password`. Then at least with password I was able to alter my account settings.
I have a problem with editing instructions: I can create instructions, then save it. But when I click on edit instructions, the instruction descriptions are empty and if I click on save again they are all empty. Browser checked was Chrome and Firefox.
Does anyone see this, too; or do I have to edit instructions all in one and then never edit them again ;)
This behavior should be corrected in a few minutes sorry for the inconvenience!
Weird one - I've got a kicad_pcb file that hangs during upload (add files to project) at about 20% for ages, then at about 30% then sits for ages and finally says 'this file type may not be supported'
I'll see if we can add that extension, how big is the file?
Its a standard kicad file so quite small. It's already a known extension - but this specific file seems to hang. Are you running some kind of virus checker on the uploads as they arrive that is perhaps having indigestion or is it just being weird ?
I'd have to check with operations, can you try and PM the file to me using the attach documents button?
The title tag here looks broken:
<title>Feedback - <a target="_blank" rel="noopener noreferrer" href="http://Hackaday.io">Hackaday.io</a> | Hackaday.io</title>
Technically both are supplyframe "products", but the blog came first and the community was meant to be an addition, iirc.
I have noticed that oftenly when you edit something (either a page, or a log or even a project description), some parts of the the text simply disappear. It just happens now when I clicked to edit this feedback.
Thanks will look into this. 1.) These nav items are using javascript there might be an issue there. 2.) Editing and saving profile should return to your profile with a gold banner at the top that says "changes have been saved".
Ok good to hear. Should have no problem with chrome/mac, could be a misbehaving extension?
I wrote a page without observing the choice "auto" was making for all my code snippets. Is there an easier way to change them than creating a new code snippet, selecting the desired coloring scheme, and copy/pasting the old one and then deleting it?
