All of us who work on Hackaday.io are reading your feedback. If we don't get back to you individually, know that we read what you wrote. Thanks for taking the time to give us feedback, we really appreciate it, you help improve the site every day!
Bugs, Feature Requests, Wishlists
Sorry about that, you can use this page to get a password set https://hackaday.io/forgotpass
Recently I tried to post a new project but when I hit the Publish button it hung up for about 1 minute then came back with a 504 - Bad Gateway error. Since then I cannot edit, nor get rid of the project... it is clogging up my feed. I have since been able to start the project anew...
CH583M deep dive - I would very much like to delete this project - I have restarted it under a different name.
User bob-easyeda sent me spam messages inviting me to some sort of hardware event. It's the most current message in my messages list if you want to see it. I couldn't find an obvious way to report a user or a private message, so I'm letting you know about it here.
Tell me you're a bot without telling me you're a bot.
Loving the site, but when I go to add / updated images to my gallery or add my first cover image I keep getting an error. Is there a specific resolution I need to set my png or jpgs to?
Try again and if its still not working message me @Richard Hogben
I don't seem to be able to find the right wing in the .stl files??
I have a specific problem. I've been daren here since the start and have that linked everywhere. I want to change my username to match a channel that I'm launching. This is a one-time thing.
I noticed that if you change project names you still get a redirect. This apparently doesn't work for actual user names. Can I get one anyway? I've sat on both names, probably against terms of service. Thank you.
If you detect all the posts in one particular language (it's obvious which one) and send them to the hold for approval (or more likely, nuke) pile, that would get rid of the majority of spam posts.
We have a change incoming that will be even better 🙂
Hi, cannot write any updates to my project, image uploading keeps showing "Access denied" error, and saving logs ended up bringing me to an error page, and everything that I have written was gone. Tried a couple of times and things still ended up not working. Project view is also not shown, and things have been very unstable recently. Do you have an estimate on when things are back to normal?
Mirroring Robin Dorst's comment a couple of days ago, I can't seem to search for my project and it didn't seem to pop up on the newest projects page as I was expecting it to. Just to add mine is a new account, been a reader for years but only just decided to start logging stuff now.
Great site otherwise!
Thanks for adding to this. It's not just the projects though it's my account and your account as well. When searching for "StabbyJack" or "Robin Dorst" there are no search results or only other projects and accounts.
it seems Hackaday.io stopped working for me. Getting very few views if any at all, no likes, no page impressions. Uploaded a complete new project yesterday, but all counters are zero, and not getting to "Trending Projects" despite a lot of content and updates anylonger.... it seems some folks have figured out how to rig the scoring system, resulting in much less engagements for other serious projects.
My account has been shadowbanned. I can not find it in the search nor can I find any of my projects even when entering the whole title.
I have this slight feeling that the search is a subsystem and somebody forgot to feed it maybe. I can't find my #Skate SAO either with the search, but #LEDodecahedron works.
I'll look into why these projects are displaying in results. You are not shadow banned.
Small thing I noticed: the description of projects doesn't format characters right, it does change it to html code, but then that code is still shown as characters and not turned into the character that was written. See this project for an example: https://hackaday.io/project/197803-han-saolo
Please support "light" mode for the website and allow user to switch between dark and light mode in settings.
If they are very new accounts following your profile, they may not appear right away. But I just tested following your profile on another older account and it worked.
Yes they should be filtered out, if you see any just report them or post here so someone can take care of it. I seem to gave cleared up most of them for now.
Oh thank you. Way better. Finally I found the "report" functionality for the project, so next time I'm gonna use it to help clearing out this crap.
Trying to add a new Page. When uploading an image, it fails with Unkown error (with that spelling mistake). Nothing special about the JPG image, only about 50kB. Sounds like the same problem as below.
I'm back to not being able to upload pictures in logs, but now also the file upoad doesn't work anymore, so I can't work around it this time.
Hey so we are running some new hardware and from my point of view it looks like one of the servers might be misbehaving, but I have Operations checking on this.
I created a profile yesterday and I'm unable to upload a profile picture. Maybe this is a similar issue.
Hi, there is an issue with SSL certificates on dev.hackaday.io (Error: unable to get local issuer certificate when trying to log in), is it possible that they are outdated? (i did update my list of trusted certificates locally) Looking at the comments in the API support page I m not the only one experiencing this.
Yep sorry we need to make some changes to get the dev api working again, stay tuned.
Thanks for looking into it! But the api itself seems to work, right? (with empty token i get a valid json 400 response) Would it be possible in the mean time to get an API key by email/PM ? And maybe also the content of the API info page?
Yeah we have a new environment built and are verifying some additional details. I don't have an estimate yet but there is progress.
Surely letting newly minted accounts post unlimited pages is asking to be spammed. Bona fide hackers don't need to post that heavily. How about implementing user quotas and rate limiting?
Agreed, example being OSHWlab.Hawaii who has spammed me.
The spam has been heavier recently and we have been focused on some hardware upgrades. There is another release planned first, then we will be able to implement something for new accounts and pages.
Spam bots are flooding the Global Feed right now and eating up your hardware power.
Deleting this accound doesn't work with github authentication. After authenticating at the delete account page I get sent back to the homepage.
