Hackaday.io Hackaday.io
Sign up Log in
Placing two Arduinos to talk to each other over IR
Two Arduinos talking to each other serially over infra-red. (no use of TSOP)
eduardo-zolaEduardo Zola
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.2k views
3 comments
40 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
  • The 2018 Hackaday Prize
View Gallery
2.2k
3
40
9
Team (1)
  • eduardo-zolaEduardo Zola
Join this project's team
completed project
MISC
arduino ir infrared photodiode eduardo zola infra red serial zolalab Zola lab serial communication til32 til78 link 2018hackadayprize
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
This project is submitted for
  • Open Hardware Design Challenge
This project was created on 01/03/2015 and last updated 11 years ago.
Description
Arduino Serial Communication Over Infrared
In this scheme, I would like to demonstrate how to perform the Serial communication over infrared photodiodes. So, I set up a simple scheme where it only uses photodiodes plus some resistors, and in this case, I chose not to use TSOP (to make it simple) once this works with a frequency of 38khz, and for that, would be necessary to build a carrier on the transmitter side. Soon I will show you how to make a similar circuit using TSOP, which makes it a more reliable communication.
Parts:
2x Arduino Uno
Photodiode TIL 32
Photodiode TIL 78
Resistor 220 Omh
Resistor 330 Omh
Resistor 1k Omh
Details and Scheme at: http://www.zolalab.com.br/references/serial2ir.php
Video: https://www.youtube.com/watch?v=TRbMfGUXVZo
Details
Log In/Sign up to comment
Sign up with Github
OR
gfxbucket wrote 05/24/2015 at 13:39 • point
Amazing project. You used same pc to transmit datas. Can I use two pc ( one on transmitter side and other on reciever ) with this same layout and code?
Bruce Land wrote 01/04/2015 at 12:58 • point
You might want to look at https://hackaday.io/project/274-infrared-communication-for-microcontroller
Eduardo Zola wrote 01/04/2015 at 13:07 • point
hello Bruce Land, thank you for the tip ! By the way, thank you very much for the skull ! :-)
A STM32F030R8 board my way, easily breadboard-able and using the embedded STM32 serial bootloader with Arduino IDE for automatic uploads
Project Owner Contributor
ARMando... (STM32F030R8)
just4funJust4Fun
we are delighted to introduce a product that will make it very easy for you to implement your electronic circuit applications.
BOARDUINO – ARDUINO ALL IN ONE BREADBOARD STAND
esrarengiz1984esrarengiz1984
Use Arduino I/O and trigger relays based on inputs
Arduino based relay board
eedgeeedge
An attendance system based on Arduino and RFID reader which will save attendance data in real-time to Google spreadsheet.
Attendance System Based on Arduino & Google Sheets
embedotronicsEmbedotronics
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Placing two Arduinos to talk to each other over IR", please tell us the reason.
Send message
Remove Member
