Another old project. I wrote this in 2013 after making too many mistakes in PCB design. It's a bare-bones 3D board viewer that accepts gerber files and displays a 3D rendering of the PCB. You can zoom, pan, and rotate the board with your mouse. I've found it very useful for double-checking before sending boards for fabrication.
You can change the look of the board by editing a JSON configuration file. I usually render them with a white silkscreen over purple soldermask and ENIG plating for some reason :-) You can make them any color you like, though (even pink).
I've developed it on linux; I have no idea what changes would be required to make it compile or run on a different OS.
It uses legacy OpenGL code. That's the version I learned years ago, and I just haven't kept up.
It uses the gerbv libraries, and won't compile unless you install the development packages. There are a bunch of other development packages you need to install, too. When I get a chance, I'll try to compile it in a clean VM linux install and make note of everything that needs to be installed.
This project is far from finished. I got it to a usable state for what I needed, and left it that way. It's served me pretty well for almost five years now. I always wanted to clean it up and publish the code, but at this point I'll settle for just publishing it.
Check it out on GitHub.
Nathaniel
KJoh
Michael Rangen
DIY GUY Chris
Awesome, nice work! I've had a lot of trouble getting Gerbers to play nice, they are really fussy. :-)
