Kitchen Player update
09/30/2015 at 00:50 • 0 commentsNow with case!
I've put the android phone into a small wooden case that I made on the laser cutter at RoboDino using the excellent tabbed box maker plugin for Inkscape
Here's what's inside
The phone is running:
- Tasker
- AutoSqueeze (tasker plugin)
- SqueezePlayer
- Headset Button Controller
There are two buttons which are connected to the microphone input which allow control of the player.
- Red button; single click = play/pause, double click = reset
- Black button; single click = next track, double click = previous track
Of course, it's also possible to control the player via any of the many Squeeze controller apps, or the web interface.
Later I may look at exposing the screen to allow track info to be displayed. But for now, this is working great.
OpenELEC
01/13/2015 at 22:21 • 0 commentsI tried the OpenELEC build from here http://www.horus.com/~hias/tmp/openelec-wolfson/5.0-rc-cirrus/
This supports the cirrus audio card out of the box, which is great. I had no problems using this for a quick test of XMBC/Kodi
But, It's not really what I'm after. It's a specialised distribution for Kodi. I'd rather use a more general purpose distro (so that I can modify it later)
Linux Images
01/10/2015 at 10:05 • 0 commentsI tried a couple of Linux Images to see if they support the Cirrus Logic audio card.
- Volumio 1.5 - does not support the audio card.
# cat /dev/sndstat Sound Driver:3.8.1a-980706 (ALSA emulation code) Kernel: Linux volumio 3.12.26+ #702 PREEMPT Wed Aug 6 17:43:49 BST 2014 armv6l Config options: 0 Installed drivers: Type 10: ALSA emulation Card config: bcm2835 ALSA Audio devices: NOT ENABLED IN CONFIG Synth devices: NOT ENABLED IN CONFIG Midi devices: NOT ENABLED IN CONFIG Timers: 7: system timer Mixers: NOT ENABLED IN CONFIG
- SqueezePlug_rpi_750 - does not support the audio card
# cat /dev/sndstat Sound Driver:3.8.1a-980706 (ALSA emulation code) Kernel: Linux lounge-audio 3.12.28+ #709 PREEMPT Mon Sep 8 15:28:00 BST 2014 armv6l Config options: 0 Installed drivers: Type 10: ALSA emulation Card config: bcm2835 ALSA Audio devices: NOT ENABLED IN CONFIG Synth devices: NOT ENABLED IN CONFIG Midi devices: NOT ENABLED IN CONFIG Timers: 7: system timer Mixers: NOT ENABLED IN CONFIG
- cirrus_audio.img - Obviously this does support the audio card.
# cat /dev/sndstat Sound Driver:3.8.1a-980706 (ALSA emulation code) Kernel: Linux raspberrypi 3.12.33+ #12 PREEMPT Wed Dec 3 09:36:24 GMT 2014 armv6l Config options: 0 Installed drivers: Type 10: ALSA emulation Card config: bcm2835 ALSA snd_rpi_wsp Audio devices: NOT ENABLED IN CONFIG Synth devices: NOT ENABLED IN CONFIG Midi devices: NOT ENABLED IN CONFIG Timers: 7: system timer Mixers: NOT ENABLED IN CONFIG
Using Squeezelite, I can set up a simple squeezebox player
Squeezelite v1.7, Copyright 2012-2015 Adrian Smith. See -t for license terms
Modifying rc.local to run squeezelite at startup:pi@raspberrypi ~ $ cat /etc/rc.local #!/bin/sh -e # # rc.local # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "exit 0" on success or any other # value on error. # # In order to enable or disable this script just change the execution # bits. # # By default this script does nothing. # Print the IP address _IP=$(hostname -I) || true if [ "$_IP" ]; then printf "My IP address is %s\n" "$_IP" fi /home/pi/Reset_paths.sh /home/pi/Playback_to_Lineout.sh /home/pi/squeezelite-armv6hf -o sysdefault:CARD=sndrpiwsp -n Lounge -z exit 0
Lounge Player
01/08/2015 at 11:14 • 0 commentsThis one will be a connected to my Hi-Fi amp. It will be housed in a Reciva Internet Radio (https://radios.reciva.com/) case:
but with the internals
replaced with a Raspberry Pi Model A+, and a Cirrus Logic Audio card
I'll use squeezelite (https://code.google.com/p/squeezelite/) as the player. First, I need to get the sound card working.
I'm going to look at the piCorePlayer image(https://sites.google.com/site/picoreplayer/) to see if that supports the sound card (I expect it doesn't)
Failing that, I'll try the 'official' cirrus_audio.img from Element14.
Kitchen Player
01/08/2015 at 01:49 • 0 commentsMy player for the kitchen consists of an old HTC wildfire phone running SqueezePlayer and a pair of Altec Lansing amplified speakers. This has been working well for a week or so. Since I already had the phone and the speakers spare, the total cost so far is A$5.29.
I'd like to add some local control buttons. I'm thinking of wiring up 3 buttons as per this article http://hackaday.com/2010/11/03/patching-into-android-music-control/ and then using Tasker and the autosqueeze plugin to control the player. I may also need Headset Droid to capture the button presses.
Matt Callow
