I'm still working on this project ;) but not I've not so much time.
Im currently working on a new version again with steppers (Nema24) and belt drives.
I also tried to make my own harmoic drive:
It didn't worked as I hoped and I spend a lot of time working on it until now but I will close this aproach.
I spent $3k on designing a gear drive before I figured out it's a no go. My two-stage hypocycloidal reduction was losing so much efficiency (even milled in metal) that it would never work.
Well the efficiency is kind of ok, but my harmonic drive was wobbling and jumping in the movement.
Next approach Nema24 stepper and 2 stage timing belts.
