Still working :)
A project log for 3D Printable Robot Arm
A printable robot arm, a little bigger than the usual hobby servo once.
andreas-hoelldorferAndreas Hoelldorfer • 08/24/2015 at 14:21•2 Comments
I'm still working on this project ;) but not I've not so much time.
Im currently working on a new version again with steppers (Nema24) and belt drives.
I also tried to make my own harmoic drive:
It didn't worked as I hoped and I spend a lot of time working on it until now but I will close this aproach.
Dan Royer wrote 08/24/2015 at 18:04 • point
I spent $3k on designing a gear drive before I figured out it's a no go.  My two-stage hypocycloidal reduction was losing so much efficiency (even milled in metal) that it would never work.
Andreas Hoelldorfer wrote 08/24/2015 at 18:59 • point
Well the efficiency is kind of ok, but my harmonic drive was wobbling and jumping in the movement.
Next approach Nema24 stepper and 2 stage timing belts.
