Done?
01/16/2017 at 21:36 • 0 commentsSo it's been a long time since I updated this, but might as well. The project has finished the next main step. I have working electronics that I installed on a custom chassis in my machined saber. Although not done the next step in the process would be to make a custom pcb, I'm also looking into using a feather M0 adalogger, since it has a built in sd slot and could save some room in the hilt.
Here is a quick viedo I did, it's mostly aimed at those in the lightsaber comunity, but it shows the electronics in action.
1.1 progress
02/29/2016 at 19:37 • 0 commentsFirst update in a while. I bought a saber with a crystal shard, and realized that my set-up was much better then I thought. At the moment I have appropriate sounds for power-on, hum, swings, clashes, and power-down working well. The new code I've written is far nicer and should be easier to expand with. I was hoping to use a modified pico-buck but that set-up requires more voltage, meaning it would require 2 batteries in series. I'm going to try and see if I can make a relatively simple direct driver set-up, although this isn't as good as a constant current, it should be simple to implement and cheap.
MTFBWY
Current State
09/22/2015 at 00:57 • 8 commentsIt's been a while since I've worked on this, but I'll still update this on my progress. I have most of the device working for version 1.1 with the Teensy 3.1. The extra processing powere means there is no noticable delay when the ideal hum repeates. It is assembled and there is good detection of swings and clashes, the lighted momentary switch is rigged up and the code is working. Essentially what is left is more documentation, adding the audio amp, and the LED current supplies. I ordered a hilt from Adaptive Saber Parts, once that arrives I'll have a better idea of how much room I have and renewed interest.
Winter Break
01/12/2015 at 05:35 • 0 commentsThe current design the microprocessor has been upgraded to a Teensy 3.1 with a micro SD breakout. The Teensy has enough processing power that it removes the need for a separate soundboard and the audio library is easily installed. This current design uses many off the self parts that require minimal modifications (such as changing gain resistors) allowing it to be easily replicated. Currently I'm working on translating the code from the previous prototype to work with the Teensy and integrating all the different components together, while documenting the steps to provide a writeup.
First Prototype
01/12/2015 at 05:35 • 0 commentsInitially the plan was to use and Arduino pro mini and a sound board to enable the system to be easily modified by others. A prototype was built to test the feasibility of correlating sound with a gyro input. Unfortunately most sound cards are unable to parse through the header of a wav file without causing a noticeable delay in the sound, which is unacceptable for extended idling. Although libraries exist that enable the Arduino to play the sound directly, they proved difficult to set up and would have made the project more difficult for others to replicate thus defeating the project goals. Dispute the low sound quality the prototype was able to detect swings and clashes reliably. Additional prototypes tested features such as powering on, off, auto-calibration and the blade shimmering effect.
aalves
