1Step 1
The small/male/micro-B end of the cable goes in your phone, and whatever you're trying to connect goes in the big/female/USB-A end of the cable.
2Step 2
Connect your Mod to its USB cable, plug that into the OTG cable
3Step 3
Plug the small/micro-B end of OTG cable in to your phone
4Step 4
Turn the Mod on, and connect to it in the Serial Monitor app.
5Step 5
We have to force Arduino not to include any HID features. The way you do this is to edit the USBDesc.h file included with Arduino. On a Mac, this is found inside of the Arduino.app itself. From the Finder, right click on the Arduino application, and choose "Show Package Contents". From there, go through Contents > Resources > Java > hardware > arduino > cores > arduino and you'll find USBDesc.h (in the 1.5.x Arduino development environment, this file is found in Contents > Java > hardware > arduino > avr > cores > arduino).
6Step 6
Open USBDesc.h and edit it:
Old:
#define CDC_ENABLED #define HID_ENABLED
New:
#define CDC_ENABLED /* #define HID_ENABLED */
You have commented out the line defining the HID_ENABLED variable.
7Step 7
You may have to quit and reload the Arduino app and then recompile your sketch for it to take effect.
