1Step 1
Dull an existing blade
- Take the electric carving knife blade and use your dremel tool to completely dull down blade.
- Insert the modified blade into your electric carving knife's attachment insert.
- Using a sharp kitchen knife, cut into the bottom of your silicone dildo to make a slit for inserting the modified blade attachment. Be sure to cut an insert deep enough so that your dildo will be securely lodged.
- Once you have fastened your dildo, you may plug in your electric carving knife to then experiment with!
Use Dremel Tool To Dull Blade
Make Sure To Dull All the Blade's Teeth
Dulling Blade Down
Keep it moving!
A Very Dull Blade, Indeed!
Use Kitchen Knife to Cut Insert
Make Sure to Go Deep Enough!
Insert Modified Attachment into Dildo!
2Step 2
Cut a new safe attachment
- Using either laser or water jet cutting, cut out our own open-source universal electric carving attachment (that doesn't have blades).
- Use a very strong plastic (we used HDPE, which was still sorta wiggly) I would reccomend water-jet cutting out of metal
Carefully Make the Slit
Go Deep!
Insert Your Plastic Laser Cut Attachment into Dildo
Or Metal Water Jet Cut Attachment into Dildo
Securely Fastened
Insert Dildo Attachment into Electric Carving Knife
3Step 3
Connecting Dildos
Cut into it
If you have a regular silicone dildo lying around (We have MANY), cut a slot in the back, and stick the attachment into it.
Using existing holes
Lots of toys have existing holes in the back for putting in a bullet vibe. We have a Tantus toy that we used here by simply wrapping the attachment with some silicone tape to make a nice firm connection.
![DSC_2538]()
Use Silicone Tape To Wrap Attachment
Create a Firm Connection
Securely Fasten Tape
blorgggg
