1Step 1
Get a lot of cardboard... then just go for it. Leave the complicated cuts( i.e. lens holes) until you've made all of your mistakes on the easy ones!
2Step 2
Design 1:
Don't make the viewing tube too big... you want the phone to be a bit bigger than the hole.
Easy to adjust lens distance to phone - lenses are mounted on separate piece of just the right height and folded to width for stability.
3Step 3
Design 2:
Requires a phone case that straddles the back cardboard edge.
You can't adjust the distance of the lenses to the screen afterwards!
Trickier to make robust. I was lucky my phone case squeezes in. Otherwise you might need to put a lid on it to keep it solidly square.
4Step 4
Tip: Use heat on bridge of frame and stretch to adjust distance between lenses to match your phone exactly.
5Step 5
Design 3: VR2Thin - See SVG file for some help if you want to try building one yourself.
Cardboard isn't firm enough... use woodboard ( from a clipboard ) or 2-3mm plastic. Thin plastic for the wing, back and top pieces.
NOTE: Focal point of lenses need to be 70mm ( i.e. these "zoomer" Dollar store lenses ) or modify design accordingly.
