1Step 1
Making the Sensor
Conductive Thread, Resistive Thread, Conductive Fabric, Foam Sheet
- Cut the foam sheet
- Prepare conductive fabric
- Cut strips
- Mounting conductive strips
- Thread needle
- Sew conductive thread
- Stitch all the way across
- Cut thread loops
- Sew opposite side of sensor
- Looks like hair follicles!
- Begin sewing resistive thread
- Complete one side and then the other
- Make Both Threads Interact Closely!
- Back Stitching
- Final!
2Step 2
Constructing Circuit
Resistor, Wires, Alligator Clips, Bread Board, Breakout Board
- Materials
- Attach alligator clips to sensor
- Make Sure Clips Make Contact With Conductive Fabric
- Looking good!
- Take your breadboard
- Place Breakout Board Onto Breadboard
- Take one wire
- Attach wire to alligator clip
- Place wire in VCC insert
- Twist Your Resitor and Other Wire Together
- Clip both to other alligator clip
- Prepare to insert onto breadboard
- Your resistor goes to GND
- Remaining wire goes to D+
- Double check your connections
- Proper connection
- Attach USB to dildo/breakout board
- Materials
3Step 3
Code Your Mod
