I always forget to turn off the light, no longer bother to turn the lights
View all 9 components
Source code:
int rolePin = 2; // pin that connects the relay int magnetPin = 3; // pin that connects magnetic switches int wait = 10000; // time to turn off light (in milliseconds) boolean doorStatus = false; void setup() { pinMode(rolePin, OUTPUT); pinMode(magnetPin, INPUT_PULLUP); } void loop() { int magnetState = digitalRead(magnetPin); if (magnetState == HIGH) { digitalWrite(rolePin, HIGH); doorStatus = true; } else{ if (doorStatus == true) { delay(wait); digitalWrite(rolePin, LOW); doorStatus = false; } } delay(5); }
View all instructions
Pim Zwager
infreq
Christoph Tack
bobricius
Yes, delete it Cancel
You are about to report the project "Arduino controlled door trigger light bulb", please tell us the reason.
