01000011 01001111 01000100 01000101
01/27/2015 at 00:49 • 0 commentsThe code is done! Woot!!
Well, enough of the code is done :)
I've published the code here - https://github.com/ibuildrockets/NixieTemperatureDisplay on my Github page.
As it stands, the code works but I want to add a 'slots' mode to reduce cathode poisoning.
With nixie tubes, one thing that can degrade their performance over a period of time is splatter - where material is ejected from the active cathode and splatters onto those surrounding it that are inactive. It won't happen overnight, but it will happen :( There's a good article on cathode poisoning here - http://www.tube-tester.com/sites/nixie/different/cathode%20poisoning/cathode-poisoning.htm
What 'slots' does is to cycle through each cathode every so often - and this can reduce the build-up of material and lengthen the life of the tubes. And that's something you're going to want to do!
The nixie clock I built in 2006 is still going today and looks like the day I turned it on - it cycles the digits every 60 seconds - as the minute rolls over, the numbers all cycle for a few seconds. Looks cool and keeps my tubes in top condition.
I'll work on this next :)
Ok! Back to the code!
The code is a bit messy - but what code isn't?
How this all works -
The OneWire DS18B20 is first declared and set to reside on Pin 19 (this is A1 on the Pro Micro)
OneWire ds(19);
Next is the declaration of the three digits for the display:
int digOne = 0, digTwo = 0, digThree = 0; //digOne - Tens, digTwo - Ones, digThree - Decimal
And finally, the 3 BCD outputs are set as follows://Tens const int tenA=2; const int tenD=3; const int tenB=4; const int tenC=5; //Ones const int oneA=15; const int oneD=14; const int oneB=16; const int oneC=10; //Decimal const int decA=6; const int decD=7; const int decB=8; const int decC=9;
This layout is to suit the inputs on the К155ИД1 BDC chip -
Testing.. Testing.. 1.. 2.. 3..
01/18/2015 at 09:46 • 0 commentsFor testing I'm using two IN-14 nixie tubes as they're easy to plug into a breadboard. The IN-12A's I'm going to use are socketed and not so easy to breadboard.
So far I've got the temperature reading working via the sample sketch & outputting BCD to the nixie drivers :)
