The emulator is the product of playing around with "bare metal" coding on the Raspberry Pi.
It's written in C and assembly and boots in less than one second, which is pretty close to the real deal. No USB keyboard support yet, to interact you need to connect a serial terminal to the UART pins on the GPIO header.
Current screen modes supported are text, HGR and HGR2 in monochrome and paging support. It loads a DSK image embedded in the kernel, next up is SD card support to access floppy images on the fly.
Stian Soreng
hengying
Aaron Angert
Dmitry
spencer
Great!
Is this project going on?
I want to know after that.
Will you continue if development is stopped?
