As said in the description, this project was created to build a simple to build robot, and keep it cheap. It may not be the ultimate robot, but it is a good way to start learning. I may improve this robot in multiple ways, however, i won't. Indeed, in most cases, each improvement would increase the coast, and/or the complexity of the project. This is why i will keep it as it is. If one is interested by a superior robot in the same class, please consult the project page of R.Hasika, my next robot based on a raspi (here on hackaday.io).
Considering all of this, i will probably post few project logs, since the robot is not beeing developped. However, if corrections are to be made (while beeing simple), i will post it.
This project is already done and finished, i just have to post all the indications. I already wrote those, but in french, so i have to translate everything here. See you soon!
Audrey Robinel
