Ultimately, what i want to get to is a stupid-bright flashlight. I simply want to drive this element at peak output, with decent collimation in a handheld (and possibly weatherproof) form-factor.
Take one 100W, 7500-lumen LED and eight 18650 Li-Ion cells. Do not stare at flashlight with remaining eye.
I spent some time today ordering parts for the second iteration of the light:
* DC-DC boost converter
* Li-Ion charge/protection PCBs
I've also got a few high quality heatsinks which I may compare to try and figure out which I ought to use, and a reflector and collimating lens.
Ideally, I want to add a switch and a charging port, in addition to upgrading the cell-holder wiring to something that will more comfortably carry that much current. With those things in place, I may be able to start planning things like a case and how to manage heat-transfer if I make this thing weatherproof to any degree.
PLEASE READ THIS IN CAUSE OF BATTERY
i know the blue lithium battery pack from ebay.
it is big bullshit. inside of the batterypack are 9 mobilephone batteries.
dont usw it, cause there not made for such an discharge energie, the LED need to use.
Use LiPo, its the only way. But be careful and read information in using LiPo and its charging
--> http://www.hobbyking.com/hobbyking/store/__9176__Turnigy_5000mAh_6S_20C_Lipo_Pack.html
I used:
100W LED Cold-white
Heatsink
Fan
150W Power converter
LiPo battery (http://www.hobbyking.com/hobbyking/store/__9176__Turnigy_5000mAh_6S_20C_Lipo_Pack.html)
when someone whats to know more about is and much details, message me:
Perner-Norman@web.de
iam from germany
