Project updates
05/10/2015 at 19:28 • 0 commentsI haven't posted project updates in a while, because I can't use my CNC without noise cancelling box anymore. And this box is still waiting to be built.
v0.4 release
04/03/2015 at 07:23 • 0 commentsv0.4 is released and available on github and from ppa.
I somewhat messed up versioning. This release actually was intended to be 0.3, but I released v0.3.1 (which had to be v0.2.1) and decided that I cant release 0.3 after 0.3.1. So, here it is.- Python setuptools are now adopted
- Tempel started to convert BCAM to Python3 (Thanks alot!)
- Save files are reworked to save space and save/load time
- Selection visualization was improved
- Safety height setting was added
- Better DXF support (added transformations)
- Basic excellon drl files import support
BCAM now supports dxf transformations
03/02/2015 at 18:45 • 0 commentsPreviously, BCAM only supported translations for block inserts, which is now fixed and BCAM now supports whole scale/rotate/translate set.
Here is some file with transformed blocks in LibreCAD:
Same file in BCAM:
And it is just right :)![]()
Undo is here
02/18/2015 at 21:47 • 0 commentsYup, Ive finally implemented undo in BCAM, as well as added safety height setting (which was hardcoded before).
Here is some picture to grab your attention:
Preview v0.3.1
02/10/2015 at 17:14 • 0 commentsThis preview is mainly about bugfixes, the deb for ubuntu is at ppa repo here: https://launchpad.net/~snegovick/+archive/ubuntu/bcam-preview
Welcome BCAMs PPA at launchpad
02/01/2015 at 14:42 • 0 commentsWell, finally I managed to find some time for packaging. Now BCAM comes with distutils integration and is available on this PPA: https://launchpad.net/~snegovick/+archive/ubuntu/bcam-preview
Drilling PCB board with BCAM
01/29/2015 at 12:32 • 0 commentsYep, let me show some kind of "hack" for drilling PCBs.
Here is a screenshot of some kicad project, we are going to work with:
Lets suppose that we drill file in excellon format and CNC machine expecting G-Code input. There is pcb2gcode project, that can help you, but it is somewhat complex to use. If you are familiar with it, then probably the way im going to describe is not for you, otherwise, follow my steps.
First lets export our project to excellon format:
Now we have a text file with drill coordinates (and instrument list, which is not very useful so far, because hobbyist machines dont usually let you use several instruments).
We want to import that file to LibreCAD, but the format of this file is not directly supported by librecad, so we want to convert it to something usable. With this one-liner we can do that:
grep ^X $1 | sed -e "s/X//" | sed -e "s/Y/, /" | awk '{printf "%s, %s, 0.0, t\n",NR,$0}' > $1.asciiSave it as drl2ascii.sh and call like that:bash drl2ascii.sh my_drl_file.drl
It will output stripped coordinates with some extra data needed for appropriate import by librecad:![]()
Lets import it in LibreCAD (go to File->Import->Read ASCII points)
Press Accept and check that points are placed correctly:
Adjust position:
Now when the points are properly placed, we can save the project to dxf and import it into BCAM:
Set material thickness prior to assigning drills to points (drill depth is set to material thickness initially) and set desired tool properties (all of these are on the right panel):
Select all the points and click drill:
Now go to File->Export and save the result to .ngc file. This G-Code can be fed to your machine:)
v0.2 release ready
01/25/2015 at 12:38 • 0 commentsFinally pocketing is fixed and works now. Code is here: https://github.com/snegovick/bcam/releases/tag/v0.2.
Development repository is obviously at github.
Aside from pocketing, scrolling with shift/ctrl was added for convenience, python logging module was finally integrated and of course a bunch of bugs was fixed. So hopefully 0.2 made BCAM better =)
The pictures are from pocketing test with Shapeoko.
The source DXF (in LibreCAD) looks like that:
Same drawing in BCAM, with pocketing applied (no finishing step, thats why border is not perfect):
Tool trajectories:
Ive set 1mm depth for test, here is the result:
Size check:
Week review
01/24/2015 at 13:27 • 0 commentsOkay, this week was quite active for project.
Ive added new pocketing code, which works much better than old code, but this code came with a price: it works slow.
Current version is not optimized at all, so I might gain some performance by staring at the code, but for now, I will have to move pocketing to separate thread or process and will add progress bar to show how far BCAM is on the way to complete pocketing path. I really-really dont want to do that because I hate slow programs, but thats the only idea I have for pocketing now. Maybe my algo is just too shitty and I will rewrite it into something better one day, who knows!
Aside from that Ive added push buttons to settings tab. Not a big deal, but it only had spinners there before, also, BCAM now starts maximized, because im tired of clicking maximize button.
The next week will be devoted to finishing of pocketing:
I will have to add progress bar, move calculation to separate thread/process and review and fix the G-Code for pocketing. After that I think it will be worth a release. But not packaged yet, just the code. The next 0.3 release will be devoted to adding python setuptools, maybe deb packaging and all that side-stuff.
More progress on pocketing
01/23/2015 at 13:37 • 0 commentsToday I've added offset for pocketing, so now it mills only the material that should be milled
d
Snegovick
