Web code updates
05/20/2014 at 00:31 • 0 commentsI updated the web code to give a table view. Voltages are just simulated data, but you get the idea.
Added Second battery to battery bank
05/19/2014 at 00:45 • 0 commentsI had some time this weekend and made up some cables to connect my second battery to my battery bank. Cables are 1 AWG and used a 1/0 gauge batter terminal connector. Clamped the connector in a vice. Heat it with a blow torch and filled the connector with solder. Once filled I push the cable into the solder. Works pretty bell with the vice take much of the heat away after the torch was removed.
While one end cooled I worked the other cable until complete. Once both cables cooled down. I used shrink wrapped and marked them with colored tape.
2nd voltage/current module complete
05/19/2014 at 00:28 • 0 commentsI built up a second voltage and current module... Was almost done and then snapped the corner off the Protoboard. Didnt affect anything but doesnt look good. I like the current sensor but not happy with the way they work on the board.... need to give some more though on how to lay these out.
Panel time
05/08/2014 at 00:02 • 0 commentsI need to make some changes to where the solar panels were located and how they come into house so the controllers and monitoring systems would be close to a network connection. At least the panels are some what portable. here is a messy view of my charge controller. The dusty keyboard monitor are for my ESX box that sits on the top shelf and are not used as part of this project.
code changes
05/02/2014 at 00:48 • 0 commentsI changed the straight line voltage get code into a function so I can call it will multiple an analog pin number as a variable. Next is to do turn the current gathering code into a function. This also offers flexibility to have some other chipset get the current and voltage and and all I need to do is fix the called code.
Calling code.
float voltage=get_voltage(A5); /get volatge on A5
Called code.
float get_voltage ( int vpin ) {
float gvolt=(analogRead(vpin)/4.092)/10;
return gvolt;
more ports ordered
05/01/2014 at 18:05 • 0 commentsOrdered 3 more ACS715 current sensors so I can finish up this project.
Life
04/23/2014 at 00:03 • 0 commentsBeen away from the project due to work and family task. Should be getting back into it soon.
Network interface
04/03/2014 at 00:43 • 0 commentsI originally had planned to use a w5100 ethernet shield, but the shield ended up using A0-A4... By moving to the non-shield module I now have access to all the analog ports on my arduino.
Created a voltage/current module
03/27/2014 at 00:25 • 0 commentsTook the messy wires and create a module that makes interface a little easier. In the next module I will skip the voltage divider module and just use a couple of resistors for a cleaner look.
FRONT VIEW.
REAR VIEW.
Current and voltage modules
03/24/2014 at 00:46 • 0 commentsThis jumble of wires has both the current and voltage modules wired up. I need a better sub-module to hold both of these modules. That will be the next task.
