NTLamp Source 3D files
02/07/2015 at 21:22 • 0 commentssource files for lamp here: NTLamp Source CAD
NTLamp Source Code
02/07/2015 at 21:11 • 0 commentsCode dump:
/* NTLamp2 Written by Jeremy Lambert Copyright 2015 All Rights Reserved This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version. This library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more details. */ //NOTE: DST compensation is in with 24 hour bug fix. set RTC with standard time. #include <Wire.h> #include <Adafruit_NeoPixel.h> #include <Adafruit_LEDBackpack.h> #include <Adafruit_GFX.h> #include <avr/power.h> #include <RTClib.h> #include <Timer.h> #include "enums.h" #define SENSOR_PIN_IRD 3 //analog #define SENSOR_PIN_PIR 7 //digital #define LIGHT_PIN 5 //digital...changed this from 4 because I think the timer is on there #define NUMPIXELS 16 //neopixel ring #define DEBOUNCE_DELAY 10 #define SUNRISE_DELAY 6000 //should generally be 6000 (6 secs a color click = 30 min sunrise) #define SUNRISE_TICK_COUNT 300 boolean dimmerActive = false; int val1 = 0; int val2 = 0; int val3 = 0; int val4 = 0; //DIMMER CONTROL int lastPWM = 0; int smoothPWM = 20; int readingPWM = 0; int currentLightPWM = 0; int DIMMER_STEP = 4; boolean clockfaceLEDState = false; uint8_t sunrise_index = 0; uint8_t mode = INACTIVE; int tickEvent = -1; Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, LIGHT_PIN, NEO_GRB + NEO_KHZ800); RTC_DS1307 RTC; DateTime Clock; Timer t; Adafruit_7segment matrix = Adafruit_7segment(); //uint8_t redList[] = { 0,8,17,26,35,43,52,61,70,79,87,96,105,114,123,131,140,149,158,167,175,184,193,202,211,219,228,237,246,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,254,253,253,252,252,251,250,250,249,249,248,247,247,246,246,245,245,244,243,243,242,242,241,240,240,239,239,238,237,237,236,236,235,235,234,233,233,232,232,231,230,230,229,229,228,228,227,226,226,225,225,224,223,223,222,222,221,220,220,219,219,218,218,217,216,216,215,215,214,213,213,212,212,211,211,210,209,209,208,208,207,206,206,205,205,204,203,203,202,202,201,201,200,199,199,198,198,197,196,196,195,195,194,193,193,192,192,191,191,190,189,189,188,188,187,186,186,185,185,184,184,183,182,182,181,181,180,179,179,178,178,177,176,176,175,175,174,174,173,172,172,171,171,170,169,169,168,168,167,167,166,165,165,164,164,163,162,162,161,161,160,159,159,158,158,157,157,156,155,155,154,154,153,152,152,151,151,150,150,149,148,147,146,145,144,142,141,140,139,138,137,136,135,134,133,132,131,130,129,128 //}; //uint8_t greenList[] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,4,6,8,10,13,15,17,19,21,23,26,28,30,32,34,36,39,41,43,45,47,49,52,54,56,58,60,62,65,67,69,71,73,75,78,80,82,84,86,88,91,93,95,97,99,101,104,106,108,110,112,114,117,119,121,123,125,128,128,130,132,135,137,140,142,145,147,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,150,149,148,147,146,145,144,142,141,140,139,138,137,136,135,134,133,132,131,130,129,128 //}; //uint8_t blueList[] = { 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,2,3,5,6,7,9,10,11,12,14,15,16,18,19,20,22,23,24,25,27,28,29,31,32,33,34,36,37,38,40,41,42,44,45,46,47,49,50,51,53,54,55,57,58,59,60,62,63,64,66,67,68,69,71,72,73,75,76,77,79,80,81,82,84,85,86,88,89,90,92,93,94,95,97,98,99,101,102,103,104,106,107,108,110,111,112,114,115,116,117,119,120,121,123,124,125,127,128,129,130,132,133,134,136,137,138,139,141,142,143,145,146,147,149,150,151,152,154,155,156,158,159,160,162,163,164,165,167,168,169,171,172,173,174,176,177,178,180,181,182,184,185,186,187,189,190,191,193,194,195,197,198,199,200,202,203,204,206,207,208,209,211,212,213,215,216,217,219,220,221,222,224,225,226,228,229,230,232,233,234,235,236,237,238,240,241,242,243,244,245,246,247,248,249,250,251,252,253,255 //}; void setup() { Serial.begin(9600); Serial.println("start setup"); pinMode(SENSOR_PIN_IRD, INPUT); Serial.println("start IRD"); pinMode(SENSOR_PIN_PIR, INPUT); Serial.println("start PIR"); digitalWrite(SENSOR_PIN_PIR, LOW); //no pullup. no need. Wire.begin(); Serial.println("start wire"); pixels.begin(); Serial.println("start pixels"); RTC.begin(); //RTC.adjust(DateTime(F(__DATE__), F(__TIME__))); //this is for setting the clock with the compile date and time. kinda handy. //TODO: don't forget to comment out for the final push to device, or it'll reset to whatever time it was compiled every time it's reset Serial.println("start RTC"); matrix.begin(0x70); Serial.println("start matrix"); matrix.setBrightness(3); Serial.println("set brightness"); startUp(); Serial.println("startup"); setColors(0, 0, 0); Serial.println("set lights off"); Serial.println("end setup"); } void loop() { t.update(); //timer tick update //clock functions uint8_t hourval =0, minuteval = 0, secondval = 0; if(digitalRead(SENSOR_PIN_PIR) == HIGH && !dimmerActive) { //Serial.println("face on"); DateTime clock; clock = RTC.now(); if (CheckDST(clock)) { hourval = (clock.hour() + 1) % 24; } else hourval = clock.hour(); minuteval = clock.minute(); secondval = clock.second(); matrix.writeDigitNum(0, hourval / 10); matrix.writeDigitNum(1, hourval % 10); matrix.writeDigitNum(3, minuteval / 10); matrix.writeDigitNum(4, minuteval % 10); bool isEven = false; if ((secondval % 2) == 0) { isEven = true; } matrix.drawColon(isEven); matrix.writeDisplay(); } else if (!dimmerActive) { //Serial.println("FACEOFF"); matrix.clear(); matrix.writeDisplay(); } //if it's alarm time if (mode != ALARM) { if (hourval==6 && minuteval ==15) //not the best way to do this { //sunrise(); //TODO: fix this shit. it hangs sometimes after 1 min } } //LED functions val1 = analogRead(SENSOR_PIN_IRD); delay(DEBOUNCE_DELAY); val2 = analogRead(SENSOR_PIN_IRD); delay(DEBOUNCE_DELAY); val3 = analogRead(SENSOR_PIN_IRD); delay(DEBOUNCE_DELAY); val4 = analogRead(SENSOR_PIN_IRD); int avgRead = constrain(((val1 + val2 + val3 + val4) >> 2), 249, 600); readingPWM = map(avgRead, 250, 600, 256, 0); int diff = abs(readingPWM - lastPWM); lastPWM = readingPWM; if (diff > smoothPWM) { return; } if (readingPWM > 50 && readingPWM < 256) { switch(mode) { case INACTIVE: if (readingPWM > 0) //TODO: huh? { mode=LAMP; Serial.println(readingPWM, DEC); fadeInWhite(254,3); delay(500); } break; case LAMP: Serial.print("Read PWM: "); Serial.println(readingPWM); int newval, mapPercent; if (readingPWM > 60 && readingPWM < 255) dimmerActive = true; if (readingPWM > 60 && readingPWM < 150) //lowering { newval = currentLightPWM - DIMMER_STEP; } else if (readingPWM >150 && readingPWM < 255) //raising { newval = currentLightPWM + DIMMER_STEP; } if (newval > 255) newval = 255; if (newval < 0) newval = 0; currentLightPWM = newval; Serial.print("Light PWM: "); Serial.println(currentLightPWM); mapPercent = map(currentLightPWM, 0, 255, 1, 100); matrix.drawColon(false); matrix.println(mapPercent, DEC); matrix.writeDisplay(); setColors(currentLightPWM, currentLightPWM, currentLightPWM); break; case ALERT: case ALARM: if (readingPWM > 1) { setOff(); } break; } } else if (readingPWM > 1 && readingPWM < 50) { Serial.println("off"); setOff(); } else { delay(200); dimmerActive = false; } } //LIGHT STUFF void startUp() { //for(int i=0;i<300;i++){ //setColors(redList[i], greenList[i], blueList[i]); //delay(10); //} delay(2000); //== 5 seconds long enough for the PIR to warm up and calibrate } void setColors(int r, int g, int b) { for(int i=0;i<NUMPIXELS;i++){ pixels.setPixelColor(i, pixels.Color(r,g,b)); pixels.show(); } } void fadeInWhite(int level, int stepDelay) { for(int s=level;s>0;s--){ setColors(level - s,level-s,level-s); delay(stepDelay); currentLightPWM = level; } } void fadeOut(int stepDelay) { for(int s=0;s< currentLightPWM + 1;s++){ setColors(currentLightPWM - s,currentLightPWM-s,currentLightPWM-s); delay(stepDelay); } currentLightPWM = 0; } void setOff() { if (tickEvent >= 0) { t.stop(tickEvent); tickEvent = -1; } sunrise_index = 0; fadeOut(2); // setColors(0,0,0); mode = INACTIVE; delay(1000); } void sunrise() { mode = ALARM; tickEvent = t.every(SUNRISE_DELAY, sunrise_tick, SUNRISE_TICK_COUNT); } void sunrise_tick() { //setColors(redList[sunrise_index], greenList[sunrise_index], blueList[sunrise_index]); sunrise_index++; } bool CheckDST(DateTime tClock) { // Daylight saving time starts on the second Sunday in March and ends on the first // Sunday in November, with the time changes taking place at 2:00 a.m. local time. // With a mnemonic word play referring to seasons, clocks "spring forward and fall back"—that // is, in spring (technically late winter) the clocks are moved forward from 2:00 // a.m. to 3:00 a.m., and in fall they are moved back from 2:00 am to 1:00 am. if (tClock.month() < 3 || tClock.month() > 11) { return false; } //April to October are in if (tClock.month() > 3 && tClock.month() < 11) { return true; } int previousSunday = tClock.day() - tClock.dayOfWeek(); //In march, we are DST if our previous sunday was on or after the 8th. if (tClock.month() == 3) { return previousSunday >= 8; } //In november we must be before the first sunday to be dst. //That means the previous sunday must be before the 1st. return previousSunday <= 0; }
full of sexy sunrise alarm data (not implemented) and arduino timing cheats.
