My boards arrived today, so when I got home from work I started to solder one channel up to see if things worked.
Spoiler alert: it works!
It took a couple of tries. Reflow soldering TSSOP chips is hard, and I still have not got the hang of it - there always seems to be one or two solder bridges hanging around, which are very hard to see even with a loupe. Also, I don't have the SMD schottkey diodes which I had planned on using, so I had to substitute a through hole diode with the leads trimmed to be a couple of mm in length.
So far I have found only one error on the board: the D3 diode is reversed. It shows the polarity pointing towards the bottom of the board, but it should be the other way. Sorry!
Below is a quick video showing off the beautiful soldered board in action... it was unrehearsed and done in one take, and hence rambles a bit, but hopefully it gives you an idea of how things look and work. Enjoy!
The Big One
This is looking really good. Nice to see the progress.
Great news mate! Did you say in the video does the supply voltage drop when in current limiting?
Correct, when current limiting kicks in it drops the voltage such that the current does not exceed the set point.
