3D LightSquared DIY Kit 8x8x8 3mm LED Cube White LED Blue Ray
Here are the detailed steps for your reference.
Parameters
Power supply voltage: 4.5~5.5V
PCB size: 11.1*12.7CM
Listing:(some components more than need)
PCB x1
3mm white blue LED x512
XH2.54-40P round female pin x2
20P IC socket x9
74HC573 DIP x9
USB to DC005 cable x1
DC005 power socket x1
18P IC socket x1
ULN2803 DIP x1
40P IC socket x 1
STC12C5A60S2 (with code) x 1
A09-103 Resisters x1
8*8 Self-locking switch x1
10uf 25V electrolytic capacitor x2
12MHz crystals x1
22pf ceramics capacitor x2
470ohm resistor x8
4.7K ohm resistor x2
LED 3mm x1
0.8mm cable x1
Step 1: Check the Font & Back of the PCB
Step 2: Cut the 40P round female pin into single needle
Step 3: Remove the plastic package of the needle
Step 4: Start the soldering
Please be noted that do not put the chip in a wrong direction
@gwatson1025 you need these three components to be able to program the cube i guess??
can you help me with them??
i want to edit the code.
