This would be the goto page for the setup of the badge (hopefully)
clone out of git
refer to this for complete instructions http://wiki.openwrt.org/doc/howto/buildroot.exigence on setting up openwrt. on ubuntu 14.10 i needed gawk as well
sudo apt-get update
sudo apt-get install git-core build-essential libssl-dev ncurses-dev unzip subversion mercurial
ubuntu 14.x, the feed update will potentially warn you about a missing gnu awk
sudo apt-get install gawk
git clone git://git.openwrt.org/openwrt
Cloning into 'openwrt'...
now head into the openwrt folder and setup the default config.
menuconfig setup
if you don't want luci, skip the luci parts. if luci fails, check for the awk version.
cd openwrt
./scripts/feeds update -a
./scripts/feeds install luci
./scripts/feeds install -a -p luci
make defconfig
make prereq
make menuconfig
i'm using things like fuse, usb support and luci, haven't really fleshed this out yet.
(Target System: Ralink RT288x/RT3xxx, Subtarget: RT3x5x/RT5350, Target Profile: VoCore) kernel/usb support/kmod-usb-storage * kernel/usb support/kmod-usb-storage-extras M (fuse isn't needed, its for me) block devices kmod-scsi-core * filesystems kmod-fs-ext4 * filesystems kmod-fuse M input modules kmod-hid * usb-support kmod-usb-hid * libraries/filesystem/libext2fs * libraries/filesystem/libfuse M luci/collections/luci(new) * luci/modules/luci-mod-admin-full * utlities/filesystem/e2fsprogs M utilities/disk/fdisk M (optional can opkg'd)
Read some of the things below about configuring the root fs, and wifi setup etc before building
building it, or make world
make -j 9
-j N number of threads (approx number of cores, adjust for machine)
V=s verbose, for debugging make, if it errors out. usually a dirclean and rebuild fixes build errors ( after the first successful one)
now wait a really long time, go read http://www.hackaday.com for a bit or something...
If the build finishes the firmware will be in the bin/ramips folder the openwrt-ramips-rt305x-vocore-squashfs-sysupgrade.bin file
for me on a virgin ubuntu install it failed on the first make, and when i re-ran it with V=s to see why, it compiled ok...
writing firmware
mtp -r writeopenwrt-ramips-rt305x-vocore-squashfs-sysupgrade.bin
firmware
alternative way, which has been working for me for a few months and doesn't reset anything to stock except the password.
scp binary to ram/tmpfs cannot be flash!, sometimes the wifi drops before it is able to flush the stdout, so doesn't always show the end, should be less than 60 seconds. I use winscp with sftp mode on windows.
sysupgrade -v /tmp/openwrt-ramips-rt305x-vocore-squashfs-sysupgrade.bin Saving config files... etc/config/dhcp etc/config/dropbear etc/config/firewall etc/config/luci etc/config/network etc/config/openvpn etc/config/system etc/config/ucitrack etc/config/uhttpd etc/config/wireless etc/dropbear/dropbear_dss_host_key etc/dropbear/dropbear_rsa_host_key etc/group etc/hosts etc/inittab etc/passwd etc/profile etc/rc.local etc/shadow etc/shells etc/sysctl.conf killall: watchdog: no process killed Sending TERM to remaining processes ... ubusd askfirst logd netifd odhcpd ntpd dnsmasq Sending KILL to remaining processes ... askfirst Switching to ramdisk... Performing system upgrade... Unlocking firmware ... Writing from to firmware ... Appending jffs2 data from /tmp/sysupgrade.tgz to firmware... Writing from to firmware ... Upgrade completed Rebooting system...
I've seen it not print out the last two lines, still seemed to work ok, the kernel just isn't flushing the print buffer.
first time password
change first password with telnet http://wiki.openwrt.org/doc/howto/firstlogin
usb setup http://wiki.openwrt.org/doc/howto/usb.storage
turn off firewall , security conference , remember?
(ssh to vocore)
/etc/init.d/firewall stop
opkg update
new config for opkg if using a version before april 2015
src/gz base http://downloads.openwrt.org/snapshots/trunk/ramips/generic/packages/base src/gz luci http://downloads.openwrt.org/snapshots/trunk/ramips/generic/packages/luci src/gz management http://downloads.openwrt.org/snapshots/trunk/ramips/generic/packages/management src/gz packages http://downloads.openwrt.org/snapshots/trunk/ramips/generic/packages/packages src/gz routing http://downloads.openwrt.org/snapshots/trunk/ramips/generic/packages/routing dest root / dest ram /tmp lists_dir ext /var/opkg-lists option overlay_root /overlay
https://downloads.openwrt.org/snapshots/trunk/ramips//packages/packages/
Examples
opkg install fdisk
opkg install nmap (uses lipcap/libstdcpp )
opkg install wavemon kismet-clientNote: will switch WLAN to promiscuous and kick you off if in client mode
opkg install kismet-serverformat usb/sd
mkfs.ext3 /dev/sd?
add dns in client mode
add nameserver 8.8.8.8 to resolve.conf
move root to a USB stick
install usb, don't mount, find if /sda etc
mkfs.ext4 dev/sda1
mount /dev/sda1 /mnt
mkdir /tmp/cproot
mount --bind / /tmp/cproot
tar -C /tmp/cproot -cvf - . | tar -C /mnt -xvf -
sync ; umount /mnt
umount /tmp/cproot
now edit /etc/config/fstab
config mount option target / option device /dev/sda1 option fstype ext4 option options rw,sync option enabled 1 option enabled_fsck 0
now reboot and check
df -hFilesystem Size Used Available Use% Mounted on rootfs 3.6G 21.4M 3.4G 1% / /dev/root 3.0M 3.0M 0 100% /rom tmpfs 14.3M 64.0K 14.3M 0% /tmp /dev/sda1 3.6G 21.4M 3.4G 1% / tmpfs 512.0K 0 512.0K 0% /dev
wlan
to use both wlan and eth0 interfaces separately, split the bridge in luci and create a new interface using vlan eth0.1
edit to enable wifi by default
package/kernel/mac80211/files/lib/wifi/mac80211.sh
and comment out
option disabled 1
to
#option disabled 1
same place to change SSID from OpenWrt to VoCore etc as well, though note via sysupgrade it remembers the old settings, so the ones compiled into the firmware only get updated on a full reset.
add packages to base build
./scripts/feed install zsh (example) zsh from packages website doesn't work, has to be built
add luci
./scripts/feeds update packages luci
notes
currently trying to add this to it, though i haven't done much
charliex
Hello, I am a newbie - have a question on vovore wifi - how low can you set txpower for wifi.
Thanks in advance
Sporan
