Diodes?!
09/19/2024 at 15:57 • 0 commentsLOL, I was so proud of this project back then...
And while admittedly my analog-design/understanding skills have diminished since then (to the point of barely even grasping how this works anymore), I can't help but feel like past-me cheated by using diodes! A *zener*, no less!
(Is it even possible, without? Dunno.)
I've plans for a binary up/down counter in another *very slow* project, so am sillily-contemplating daisy-chaining 8 (maybe 16) of these as a ripple-counter.
It would be *absurd* to do-so. But that project is absurd by intent... Though, mostly in trying to do things with as *few* components as possible, so this thing's excess of components (times 16!!!) would complement that in a strange way.
That project also requires an 8-bit (maybe 16) magnitude-comparator... Compare one byte/word to another, output which is greater on one of two pins. There's a 4000-series chip for 4bits of that, and it was quick-and-easy to get going.
But, I was contemplating reimplementing it with transistors, or something similar, and noticed just how *huge* the internal logic in that chip is.
So, I started contemplating different ways of reimplementing it... And I think I came up with a circuit using 7 (or 15) XORs, and a bunch of diodes. The diodes are mostly for 'open-collector' OR gates, but also as, essentially, active-low open-collector [un]buffers with output-enables... So, [un]buffers with a "BLOCK" input... which, allows for essentially multiplexing all the inputs and passing-through only one (pair).
It's kinda groovy, but it also is a bit power-hungry, and slow... and... a *lot* of diodes.
In the process, I also discovered that XOR isn't really as-complicated a gate as I'd previously thought... just parallel an OC-NAND with an OC-NOR... which is even simpler by paralleling an OC-AND with an OC-OR, then inverting the output... Four diodes, a transistor, and a few resistors! Right???
Anyhow, before I confirmed my discovery I realized it was a LOT of diodes for 8-bits... And in the background I briefly (and somewhat begrudgingly, since I'd somehow had it in-mind that diodes and transistors were *required*) acknowledged how simple it is to make an XOR with a relay... Simply wire the two signals to the relay-winding. Done.
But I kept fighting with diodes and transistors, and it's not bad. And I think I could reduce diode-counts tremendously if I'd combined my output-enablable-[un]buffers with my ORs... instead of daisy-chaining them... (three-input OR?! Really? Heh... 8-input? That can't be possible, can it?! Sheesh.)
But I stopped when I realized the current design had something like 4d+1t+4d+2d= 10diodes and a transistor (which I guess isn't so bad, really) and numerous pull*down* resistors per bit... (and the tremendous amount of power it would take to "block" 7 of 8 330ohm resistors in parallel tied to ground. Not that I care so much about power-usage in a project as absurd as this, but that the input-signals just aren't capable of driving such a heavy load... (add a transistor!).
So, of course, maybe this could be redesigned with active-high instead of active-low, and instead of 330ohm pull-downs, I could use kiloohms for pull-ups...
But that's when I realized... Hey, there's *zero* requirement for diodes/transistors, here... [Somehow I think I had it in-mind that even though this thing is *slow*, this particular piece of it had to be faster than relays would allow? WHAT?]. In fact, the next piece of the system, following the magnitude-comparator, is *really* slow... we're talking on the order of half a second [minimum] to possibly many tens of *seconds*, depending on how big the difference between the two binary inputs.
And, sheesh... I mean, the whole point of this project *is* the fact of tying-together a fast system, making it reliant on a slow one, for its most basic needs. The Point is to make these operations understandable to a human in realtime. Y'all's fighting for gigaflops while this project is best-off running at FIPS (Fractions of an Instruction Per Second)!
So... a few milliseconds for relays to switch is a problem?
LOL.
So, then I worked-out the circuit, using relays, and... it took 5 minutes (vs the *hours* spent with diodes and transistors!). And all it takes is one DPDT relay per bit... And, actually, the lowest bit doesn't even need a relay. 7 (or 15) relays, total.
Sheesh!
(That's for the magnitude-comparator. Otherwise, I still need the binary up/down counter... which eventually led me to think about repurposing *this* project and its tremendous mass of circuit-elements... just to add to the new project's utter insanity).
But, driving relays from CMOS outputs... now we need transistors. And doing-so for our XORs means H-bridges! Yeah. That *could* be accomplished with one additional SPDT relay per input, but now we're talking 8bits*2 (or 16bits*2) 16 or 32 relays (well, 14 or 30... and driver transistors!) *just* to make our 7 XORs interface with the input-signals.
H-bridges... well, I mean, I could go the route of discrete transistors, but still we're talking at least 2 transistors per bit! So, (Oh, hey... I might be able to do something with a split powersupply? hmm...)... So, yahknow, comparing two 8bit values is 16bits... 32 transistors just to use relays? Hah!
But... I mean... This project has *zero* requirements... And, I happened a while-back to invest in a bunch of audio-speaker-amplifier ICs... (me? who seldom does analog? But they were SO CHEAP!) Which... I did, actually, once try (successfully!) to use as motor-drivers. If I recall, they were designed for car stereos, and have separate drivers for front and back... 4 h-bridges in each chip. 8bitsx2, 4 chips!
Ahhh, it's coming back to me... no, the 4ch chips are designed to output positive *and* inverted to drive a speaker from a single input... So, actually, we could only do two XOR relays from them. But I'm pretty sure I also got a similarly large supply of 2ch amps with separate inputs for each half-bridge... hmm...
Anyhow, this is all crazy. But I guess the point of the project has become a system that makes use of very dissimilar technologies for different subsystems that *could* all be (and usually are) made from the same technology.
Sure, why not?
Op Amp Challenge Accept-ed(?)
04/25/2023 at 12:19 • 2 commentsI do not at all consider myself good at analog circuitry. It's one of those things that intrigues me conceptually, but has mostly eluded me in the few times I've found the time [and courage!] to try again over the last three decades.
Thus, seeing mention of the "Analog Challenge" on The Blog gave me a bit of a forlorn sigh...
Until it finally came to me...
Somehow I'd forgotten this project, my proud analog moment of a few years back!
This project is rather ridiculous, if you think about the number of transistors involved, and the crazy slew/arrangement of support components. And, I'd kinda prided myself on the fact it involed only one active component, heh! And a zener? Really? Can that be considered "passive?"
But, at the time I didn't have my TTL collection with me, so I thought I'd see what could be done with what I had on-hand [What weird stage in my life did I go through when I'd have comparators with me but not TTL?!]
Progress was also motivated by the thought that maybe someday I could use the same inspiration for this circuit [a pen-clicker] to acheive similar with a single transistor. A fellow Hackadayer beat me to that (link in this project's description), which I actually found to be a bit of a relief, since this design relies heavily on the fast/full-swing switching of a comparator, which surely a single transistor wouldn't provide...
...And, frankly, I'd kinda grown to love the ridiculousness of this circuit's excessive support-circuitry, when a few transistors in a digital 7474-like design could've surely done the job without any "spooky analog" weirdness like slightly-differing capacitor-charging delays or voltage-dividers outputting only slightly different values, or a friggin voltage-regulator, heh! And, frankly, how much more sophisticated, internally, a comparator is than a few NAND gates.
And to think, it actually worked; this crazy analog design from a guy who had had little other than bad luck in decades of attempts designing analog!
Hmmm...
So, what about an Op-Amp?
I mean, they're just comparators with lower gain and larger delays, right? Albeit, internally even more complicated and precise... Further adding to this project's appealing ridiculosity...
Challenge Accepted.
Maybe I'll luck-out and it's a simple drop-in replacement[?]. But, as part of my own added challenge, I think I'll again attempt this with parts on-hand. Which basically amounts to LM-series from the 80's. We'll See!
VID
04/16/2018 at 00:49 • 7 commentsHere it is, in all its glory!
First, the audio is converted to PWM.
Then both PWM edges are converted to falling-edge pulses.
This, then, could be fed directly into a floppy drive's "write data" input, storing the PWM on-disk.
When read-back from the disk, the floppy drive will give these same falling-edge pulses to indicate each edge of the recorded PWM.
That, then, gets fed into my single-comparator T-Flip-Flop, to convert those falling-edges back into PWM, then directly drives a speaker.
Ahh, right... So, this video was recorded months ago... long before I ran the 500KHz simulations. I can't recall the frequency this is running at, but it's surely slower than 500KHz, otherwise, as my conclusions, after running the sims... concluded... This system probably won't run at 500KHz, with the LM311's I used.
I do have faster (2ns!) comparators in the ol' storage-unit... but haven't really decided to go that route, much easier to use a 7474... and, realistically, I only need 500KHz for the *image* portion of #Floppy-bird, which wouldn't benefit from a T-FF at all, being that it'd still have to go into the uC for processing...
500khz components, explanation
01/27/2018 at 02:39 • 2 commentshere's the components determined in the sims....
R1-4 are two voltage-dividers to bias Vi+ at 4V and Vi- at 3V. Thus, when the comparator is off and no toggling occurs at the input, the comparator's output is high (well, the LM311 is open-collector/Hi-Z... and, confusingly, I've the habit of calling it "off" when Vi+ > Vi-, and "on" when the output is low).
So... it remains "off" as-biased... 4V > 3V.
A pull-up resistor is not shown on the output... but it's unnecessary for this circuit, only for those following,
D1 and D2 isolate the output's feedback-paths to Vi+ and Vi-, so's we don't have to consider each's present voltage on the other (especially when the output is Hi-Z).
R7 and the Zener diode form a crude voltage-regulator. Thus, when the comparator output is low, Vi+ will be pulled to ~1V.
When the comparator is on, the zener also prevents the next falling-edge input from dropping Vi+ lower than Vi-. It essentially keeps Vi+ from seeing that falling edge.
(I imagine the zener could be replaced with cleverer resistor usage, but... Math! I'm not so great with analog circuits, it always seems every 'building-block' thrown in has a dramatic effect on all the others. Here, I'm attempting to reduce that effect. Thus diodes, and AC-coupling.)
So, now, Vi+ has two steady-states; 3V and 1V.
The feedback-path for Vi- is slightly more complicated. R9 and C3 limit the rate that Vi- is affected by the comparator's turning on (and off). Similarly, R8 and, again, C3 cause input-edges to be smoothed slightly before entering Vi-.
Thus, the comparator turns on, latching Vi+ low when the present value of Vi+ is lower than the *previous* value of Vi-.
(But wait! That's wrong! So it *does* still function as I originally planned, the spike on Vi+ is larger than that on Vi-, but still simultaneous, so they cross... huh. No.. wait, these don't even look the same. Sheeit. Now I remember why a short lab-report always took HOURS longer than seemingly anyone else's took them.)
But, again, Vi+ essentially doesn't see the next falling-edge, so that slight delay from C3 doesn't stop that edge from bringing Vi- below the steady Vi+, turning the comparator off, again.
Now, as for the rising-edges on the input...
If the two paths were identical, both inputs would rise, briefly, together, and so wouldn't cross-over. Thus, there'd be no change as far as the comparator is concerned...
But of course, the two paths differ (otherwise the same would be true for falling edges, and nothing would happen, ever). So... I didn't really put a huge amount of thought into the rising edge... Instead, some early values for R8 and 9 led to the "on" steady-state voltages for Vi+ and Vi- to be "too close for comfort", so I tweaked those values so that Vi- would be dramatically lower, in that state... nearly half a volt. R6 was initially chosen to be higher than R5 so that the spikes on Vi- would be smaller than those on Vi+, but this is where the progression led me, during simulation.
(BTW, when I was in school, running a simulation meant setting up the circuit, clicking 'run' and waiting several minutes. Now it's possible to do sims in 'real-time', wherein you can change component values while simulating. Very handy.)
Here were my original proof-of-concept component choices:
And, again, those after experimenting:
(It may be possible to remove the feedback path to Vi-, altogether. The original intent was to bring its value close to Vi+ at 1V, so the *smaller* spike on Vi- would cross-over the steady Vi+. That may be less relevant now that both inputs use the same capacitances and resistances... hmmm...)
Some choices and changes were definitely random experimentation, but certainly most were more thoughtful... input capators, T=RC... the "1-to-ten rule"... throw in some rough estimates with some rough expectations, tweak accordingly.
OTOH: sims are not reality... a prime example being my intended use of an LM311... this guy has a response-time of 200ns. But the widths of my negative-pulses are as short as 100ns, latching never occurs. The comparator (op-amp, actually) in the sims responds immediately. Whoops. I do have faster comparators, but this was more a proof of concept based on parts at-hand than a necessity. I also have 7474's. Done.
OTOOH, leads me to wonder if a flip-flop can be designed with a single transistor.
Also, I swear I saw some sims where a negative input-pulse caused a positive pulse... something to do with diodes' capacitances, maybe? Or maybe just the switching of the comparator. But, the comparator doesn't pull-up, and why would it bounce back down...? (Red line at falling edge of blue). Reminded of @Ted Yapo 's diode-inverters.
DAGNABBIT *NO*!!!
I spent a LOT of time considering the rising edge when I designed this month(s?) ago. How could I have forgotten?!
Sims
01/26/2018 at 03:51 • 0 commentsi've done 'em before, but not at my desired speeds... I'm planning roughly 500khz for another project. Also, I didn't look closely at the edges,
I usually use Paul Falstad's online simulator, but it doesn't work so well on this phone, so branched out for a (woo, 24-hour...) trial of EveryCircuit. Seems pretty good, but not in my budget.
So, new component values. But looks like it should work great!
Then... I remembered that the LM311 I plan to use has a delay of 200ns.... erm.
So tried to simulate that... and it *dramatically* slows the toggle-frequency. Nevermind my source guarantees low-pulses down to 0.1us.
Also, not certain it'd still function with more real-world slew-rates at the input.
But, I'm still pretty content with this /wonky idea's functioning at all!
Eric Hertz
