The Toadstool
Go beyond the Arduino and Launchpad with the Toadstool
The Toadstool is designed to make your prototyping life easier and faster.
I was looking to break away from dev-boards and start building my own mare-metal microcontroller projects. After wiring up an MCU on a breadboard a few times I realised it's messy and not much fun. The Toadstool gives you a leg-up by allowing you to easily and quickly get the MCU onto the breadboard, without sacrificing flexibility.
The first round of prototypes are designed for the ATmega328P and the MSP430-G2553
While I was at it, I designed a standard header. This will allow breakout modules (I call them CAPs) to be added to the Toadstool without creating rats-nests of wires or using up precious breadboard space. This header includes SPI/I2C/TWI/UART.
I wanted to achieve a few things with the Toadstool:
  • Win back the flexibility that some dev boards (like the Arduino) don't give you
  • Plug directly into a breadboard to make breadboard-based MCU projects quick to get going
  • Allow a range of microcontrollers to be used
  • Allow I2C, SPI and UART breakout modules to easily be connected to any of the Toadstool boards
Currently there are 2 Toadstool boards in the works:
  • Toadstool mega328: Based on the Atmel ATmega328P
  • Toadstool MSPg2553: Based on the TI MSP430G2553
Key design features:
  • The shape: move all the supporting components out of the way of the breadboard, to maximise use of the limited breadboard space.
  • Power: an on-board regulated power supply, allowing you to select the operating voltage. Polarity and over-current protection./
  • Speed: Select the crystal that works best for your specific project (ATmega only)
  • DIP: Where possible I'll be using DIP packages. A little more bulky, but you can switch your MCU out.
  • CAPs: Breakout modules can be connected to a standard I2C/SPI/UART header
Toadstool CAPs
These are the breakout modules that connect to the board's common header. Here's a cap, and how it connects:
Toadstool RTC CAP
Toadstool with Cap
Currently working on :
  • EEPROM 24LC: an I2C interface EEPROM module (Microchip 24LC128)
  • RTC MCP79400: an Real Time Clock modules (Microchip MCP79400)
  • USB-UART 2200: a USB to UART converter (Microchip MCP2200)
I'll keep updates coming in the project log. Thanks for the interest!
  • Prototype #2 Tested
    Andrew Retallack06/04/2015 at 07:02 0 comments
    A second batch of PCBs arrived from China a couple of weeks ago, and I've had a chance to assemble and test them. Apart from a few minor cosmetics on the silkscreen, I'm happy with the outcome - the gallery has been updated with latest images.
    What changed:
    • Toadstool CAP headers changed to provide better stability
    • Broke out the Reset pin into the Toadstool CAP header
    • Low-profile SMD reset button, so it can be pressed with a Toadstool Cap mounted
    • Aluminium caps now replace the tantalum ones
    • Silkscreen and layout tweaks
    Where to from here?
    I'm testing the range of Toadstool CAPs that arrived in the same shipment:
    • an EEPROM module based on the Microchip 24LC128
    • a RTC using in the Microchip MCP79400
    • a USB-Serial converter using the Microchip MCP2200 (having a bit of trouble with this one!)
    Toadstool CAP - RTC
    Toadstool CAP - EEPROM
    Toadstool CAP - USB-Serial
  • ATmega Prototype #1 Tested
    Andrew Retallack04/29/2015 at 05:53 0 comments
    The ATmega328P prototype of the Toadstool arrived a month ago and has been through some solid testing. Here it is assembled:
    Toadstool Mega328
    I found a couple of usability issues with the physical layout which I've corrected:
    • The 2x6 header for the "Toadstool Caps" (breakout boards) has been split into two 1x6 headers to add stability to the Cap
    • The reset switch has been switched (!) for an SMD low profile version to prevent the Toadstool Cap from obscuring it.
    • The Tantalum caps have been replaced by Aluminium ones to make the board more reflow friendly (listen to this great podcast on capacitors)
    • A number of changes to silkscreen to make it more readable
View all 2 project logs
