Prototype #2 Tested
06/04/2015 at 07:02 • 0 commentsA second batch of PCBs arrived from China a couple of weeks ago, and I've had a chance to assemble and test them. Apart from a few minor cosmetics on the silkscreen, I'm happy with the outcome - the gallery has been updated with latest images.
What changed:
- Toadstool CAP headers changed to provide better stability
- Broke out the Reset pin into the Toadstool CAP header
- Low-profile SMD reset button, so it can be pressed with a Toadstool Cap mounted
- Aluminium caps now replace the tantalum ones
- Silkscreen and layout tweaks
Where to from here?
I'm testing the range of Toadstool CAPs that arrived in the same shipment:
- an EEPROM module based on the Microchip 24LC128
- a RTC using in the Microchip MCP79400
- a USB-Serial converter using the Microchip MCP2200 (having a bit of trouble with this one!)
ATmega Prototype #1 Tested
04/29/2015 at 05:53 • 0 commentsThe ATmega328P prototype of the Toadstool arrived a month ago and has been through some solid testing. Here it is assembled:
I found a couple of usability issues with the physical layout which I've corrected:
- The 2x6 header for the "Toadstool Caps" (breakout boards) has been split into two 1x6 headers to add stability to the Cap
- The reset switch has been switched (!) for an SMD low profile version to prevent the Toadstool Cap from obscuring it.
- The Tantalum caps have been replaced by Aluminium ones to make the board more reflow friendly (listen to this great podcast on capacitors)
- A number of changes to silkscreen to make it more readable
