The arduino library supports A/D conversion at about 13 KHz, not fast enought for a useful audio-rate oscilloscope. Rewriting the acqusition loop to directly access the ADC reqisters speeds up conversion (including loop overhead) to about 688,000 samples/sec, a considerable improvement. The sampling loop becomes quite short. If we define registers and constants as follows:
#define ADC_MR * (volatile unsigned int *) (0x400C0004) /*adc mode word*/ #define ADC_CR * (volatile unsigned int *) (0x400C0000) /*write a 2 to start convertion*/ #define ADC_ISR * (volatile unsigned int *) (0x400C0030) /*status reg -- bit 24 is data ready*/ #define ADC_ISR_DRDY 0x01000000 #define ADC_START 2 #define ADC_LCDR * (volatile unsigned int *) (0x400C0020) /*last converted low 12 bits*/ #define ADC_DATA 0x00000FFF
Then the sample loop becomes:
ADC_CR = ADC_START ;
for (i=0; i<320; i++){
// Wait for end of conversion
while (!(ADC_ISR & ADC_ISR_DRDY));
// Read the value
analog_data[i] = ADC_LCDR & ADC_DATA ;
// start next
} For TFT display connections, look at the Adafruit tutorial, and consult the source code above. I used the following with the line//#define USE_ADAFRUIT_SHIELD_PINOUT in the file Adafruit_TFTLCD.h commented out.
// The control pins for the LCD can be assigned to any digital or // analog pins...but we'll use the analog pins as this allows us to // double up the pins with the touch screen (see the TFT paint example). #define LCD_CS A3 // Chip Select goes to Analog 3 #define LCD_CD A2 // Command/Data goes to Analog 2 #define LCD_WR A1 // LCD Write goes to Analog 1 #define LCD_RD A0 // LCD Read goes to Analog 0 #define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin // With shield defined (from pin_magic.h) // LCD Data Bit : 7 6 5 4 3 2 1 0 (LCD data pin) // Due pin # : 7 6 13 4 11 10 9 8 (board pin #)
A minor rewrite displays the frequency of the periodic input wave every second.
Bruce Land
Natalia
Makerfabs
muzi
agp.cooper
how to show the signal on serial osciloscope sir? please help me
