Using the brass nozzle makes the task of inserting carbon tube into a cable end sleeve easier by a felt order of magnitude:
Added some fischertechnik around it and voilà! It's basically ready for production:The cool thing about the tube is that it has a variable diameter (or width when flat). Making it wider also makes it shorter, but its resistance doesn't change significantly. Then resistance per length can therefore be adjusted a bit, leaving some room for fine-tuning when I'm past the more-power-is-better stage.
Made ten of these in 20 minutes:
