Connections
A project log for Carbon/silicone hotplate
Because simply screwing or soldering resistors to a plate is boring.
christophChristoph 02/15/2015 at 22:500 Comments
Taking four filaments (2 pairs of two) and putting a sleeve around wasn't as hard as expected. First, using two cable straps, I separated the filaments I wanted to use. They were easy to push underneath the fabric, and have rounded ends:
Then I fiddled them into a sleeve and gently squeezed it:
The resistance is a bit too high (I expected about 5 Ohm), but not that bad:
It turned out that I should have shortened the aramid filaments before adding the sleeves, like for the next sleeve in this picture:
I thought about putting more or less than fours filaments into one sleeve, but with two it might get too crowded, and more than 4 is probably just too hard to do. Also, four will be fine for either brazing or clamping, so I'll stick with that.
