cnc_masin_v2_export.stp
exported assembly file with all components. Date 18 Jan 2016 snapshot of the plans.
stp -
5.08 MB -
01/18/2016 at 10:00
Download
6mm_nestings_kokku.dxf
The main machine parts, kerf compensated, 6mm plexi (or any other 6mm thick material, initial design was for 6mm aluminium).
241.39 kB -
01/28/2016 at 10:46
Download
2mm_nestings_kokku.dxf
Kerf compensated, cable chain parts (2mm plexi but any 2mm thick material should work, also published in CrabCAD site without kerf compensation)
AutoCAD DXF -
41.36 kB -
01/18/2016 at 09:38
Download
x-plate.dxf
a piece of the machine, provided in a separate file as well just on case. not kerf compensated.
AutoCAD DXF -
23.41 kB -
01/18/2016 at 09:36
Download
y-side-plate.dxf
AutoCAD DXF -
22.04 kB -
01/18/2016 at 09:36
Download
y-plate.dxf
AutoCAD DXF -
18.27 kB -
01/18/2016 at 09:36
Download
y-back-plate.dxf
AutoCAD DXF -
18.75 kB -
01/18/2016 at 09:36
Download
x-under-rib-horisontal.dxf
AutoCAD DXF -
19.01 kB -
01/18/2016 at 09:36
Download
x-under-rib-vert.dxf
AutoCAD DXF -
17.34 kB -
01/18/2016 at 09:36
Download
x-side-plate.dxf
AutoCAD DXF -
21.76 kB -
01/18/2016 at 09:36
Download
x-front-plate.dxf
AutoCAD DXF -
26.11 kB -
01/18/2016 at 09:36
Download
x-alus-1.dxf
AutoCAD DXF -
20.28 kB -
01/18/2016 at 09:36
Download
z-top-and-bottom-plate.dxf
AutoCAD DXF -
20.02 kB -
01/18/2016 at 09:36
Download
z-plate.dxf
AutoCAD DXF -
21.41 kB -
01/18/2016 at 09:36
Download
x-alus-2.dxf
AutoCAD DXF -
20.28 kB -
01/18/2016 at 09:36
Download
nema17_extraplate.dxf
AutoCAD DXF -
18.61 kB -
01/18/2016 at 09:36
Download
Jupid.ods
A list of plexi parts and a note on how many of each do you need
spreadsheet -
11.53 kB -
01/18/2016 at 09:28
Download
Mechanical system.ods
A spreadsheet - it's work in progress so not some kind of finalized list, but if anyone wants to take a look then its here.
spreadsheet -
21.66 kB -
01/18/2016 at 09:27
Download
