solder_prt2.stl
This is the outer casing "rubber band holder"
simplify3d_stl - 260.04 kB - 01/26/2018 at 20:11
Download
solder_button_v2.stl
This is the button file
simplify3d_stl - 136.51 kB - 01/26/2018 at 20:11
Download
solder_button_v2.prt.1
This is the part file for the button if you wish to modify it for yourself!
1 - 286.60 kB - 01/26/2018 at 20:11
Download
solder_prt2.prt.1
This is the part file for the rubber band holder if you wish to modify it for yourself!
1 - 241.44 kB - 01/26/2018 at 20:11
Download
