1Step 1
Install you Raspberry Pi with NOOBS:
2Step 2
Install and configure SBFSpot for the logging of your SMA inverter
SBFSpot installation on the Rpi
Make sure that csv logging is enabled, since my python script uses these files.
3Step 3
Log in using ssh on the Pi
Install the wiringpi2 library on the raspberry:
sudo apt-get update sudo apt-get install python-dev python-pip sudo pip install wiringpi2 -
4Step 4
Now the actual script that filters the power data from the SMA logging:
mkdir /home/pi/scripts nano /home/pi/scripts/show_actual.pyAdjust the values in #defines to match your preferences
#!/usr/bin/python import time import datetime import wiringpi2 as wiringpi import os.path #defines: system_name="Your_Pv_System" # System namen in SBFspot sbfspot_log_location="/home/pi/smadata/" # logging of SBFspot meter_zero_offset=0 # normal range: 0-1024, offset range = 100-1024 meter_max_offset=0 # normal range: 0-1024, offser range = 0-824 max_kwh_day=30 # max kwh generated in 1 day max_power=6000 # max inverter AC power feed debug_mode=1 # print information while running #initialise PWM wiringpi.wiringPiSetupGpio() wiringpi.pinMode(18,2) # pwm only works on GPIO port 18 wiringpi.pwmWrite(18, 0) # duty cycle between 0 and 1024. 0 = off, 1024 = fully on previous_value = 0 daynight="none" while 1 == 1: prev_daynight=daynight #Read & parse SBFspot generated datafile fulldate= str(datetime.datetime.now().year) + str(datetime.datetime.now().month).zfill(2) + str(datetime.datetime.now().day).zfill(2) datafile=sbfspot_log_location + str(datetime.datetime.now().year) + "/" + system_name + "-Spot-" + fulldate + ".csv" if os.path.isfile(datafile) == True: file = open(datafile) for line in file: pass # Get last line in log file.close() actual_data = line.split(',') # Appoint values from csv columns actual_power = actual_data[20] total_kwh_today = actual_data[22] gridrelay_status = actual_data[29] #Daytime, gridrelay_status = "Closed" if gridrelay_status == "Closed": # Day mode: show actual power daynight = "day" actual_value = float(actual_power) maxvalue=max_power else: daynight = "night" # Night mode: show total energy generated today actual_value = float(total_kwh_today) maxvalue=max_kwh_day if actual_value > maxvalue: actual_value = maxvalue if (previous_value != actual_value) or (prev_daynight != daynight): if debug_mode==1: print "gridrelay: " + gridrelay_status print "Actual Power:\t\t" + str(actual_power) print "Total kWh today:\t" + str(total_kwh_today) for i in range (1,21): newvalue = previous_value+((actual_value-previous_value)/20)*i value_out = int(meter_zero_offset+(newvalue/maxvalue)*(1024-meter_zero_offset-meter_max_offset)) wiringpi.pwmWrite(18, value_out ) if debug_mode==1: print ("New val: %8.3f\tMax val: %d\tPct: %6.2f\t0-1024: %4d" % (newvalue, maxvalue, (newvalue/maxvalue)*100, value_out)) time.sleep( 0.25 ) previous_value = actual_value else: time.sleep( 1 ) else: time.sleep ( 5 ) -
5Step 5
Test the script by executing the following command:
sudo python /home/pi/scripts/show_actual.pyIt should show something like the following output (nighttime):pi@raspberrypi ~ $ sudo python /home/pi/scripts/show_actual.py gridrelay: Open Actual Power: 0.000 Total kWh today: 5.987 New val: 0.299 Max val: 30 Pct: 1.00 0-1024: 10 New val: 0.599 Max val: 30 Pct: 2.00 0-1024: 20 New val: 0.898 Max val: 30 Pct: 2.99 0-1024: 30 New val: 1.197 Max val: 30 Pct: 3.99 0-1024: 40 New val: 1.497 Max val: 30 Pct: 4.99 0-1024: 51 New val: 1.796 Max val: 30 Pct: 5.99 0-1024: 61 New val: 2.095 Max val: 30 Pct: 6.98 0-1024: 71 New val: 2.395 Max val: 30 Pct: 7.98 0-1024: 81 New val: 2.694 Max val: 30 Pct: 8.98 0-1024: 91 New val: 2.994 Max val: 30 Pct: 9.98 0-1024: 102 New val: 3.293 Max val: 30 Pct: 10.98 0-1024: 112 New val: 3.592 Max val: 30 Pct: 11.97 0-1024: 122 New val: 3.892 Max val: 30 Pct: 12.97 0-1024: 132 New val: 4.191 Max val: 30 Pct: 13.97 0-1024: 143 New val: 4.490 Max val: 30 Pct: 14.97 0-1024: 153 New val: 4.790 Max val: 30 Pct: 15.97 0-1024: 163 New val: 5.089 Max val: 30 Pct: 16.96 0-1024: 173 New val: 5.388 Max val: 30 Pct: 17.96 0-1024: 183 New val: 5.688 Max val: 30 Pct: 18.96 0-1024: 194 New val: 5.987 Max val: 30 Pct: 19.96 0-1024: 204Crtl+c to quit....
6Step 6
Now to make the datalogger and meter controller run automatically at boot:
sudo nano /etc/rc.localAnd add the following.2.lines before the "exit 0"/home/pi/scripts/SBFspot.sh > /dev/null 2>&1 & python /home/pi/scripts/show_actual.py > /dev/null 2>&1 & exit 0 -
7Step 7
Create an additional script to run SBFSpot every 5 seconds, except in the night time...
Tweak the location to the SBFspot binary if neccessary
nano /home/pi/scripts/SBFspot.sh#!/bin/bash sbfspot_bin_path="/home/pi/smaspot/SBFspot/bin/Release" while true do cd $sbfspot_bin_path if timeout 10s ./SBFspot -v | grep -q "it's dark"; then # It is dark... using 5 minute delays and skipping file writes sleep 300 else # Update log every 5 seconds sleep 5 fi done -
8Step 8
(Optional): If you are using a wifi dongle, it's wise to monitor the connection (no auto reconnect on NOOBS)
sudo nano /home/pi/scripts/keep_wifi_alive.shadd the following content:#!/bin/bash if ifconfig wlan0 | grep -q "inet addr:"; then echo else date=$(date) echo "Wifi down @ " $date ", Trying to reconnect" >> /tmp/wifi_status ifup --force wlan0 if ifconfig wlan0 | grep -q "inet addr:"; then echo "Reconnection succesful!" >> /tmp/wifi_status else echo "Reconnection not succesful, trying again in 1 minute" >> /tmp/wifi_status fi fiMake it executable:
chmod +x /home/pi/scripts/keep_wifi_alive.shNow auto run the check every minute:
sudo crontab -eadd the following line in the bottom of the file*/1 * * * * sudo /home/pi/scripts/keep_wifi_alive.sh >/dev/null 2>&1
Strangely, the Rpi has a bug in crontab which requited te "sudo" above... Hell.. ugly, but it works ;)
9Step 9
Now the software configuration should be fine :) Reboot the Pi and start connecting the hardware... (instructions will be added when I find the time)
Sander Los
Hi SBF: Of course there is no problem linking to this page! Thanks for the thumbs up ;)
In case someone runs into the gridrelay issue, i'll make sure to create a fix in the code so everyone can enjoy day/nicht settings...
Hi Sander,
Very nice project! I added a link on the SBFspot project page, I hope you don't mind.
One remark: gridrelay_status is not available on all inverters (e.g. SB 3300), so there it might go wrong.
