I finally found some enclosures I like !!!
08/28/2014 at 23:54 • 0 commentsI found these extruded aluminium parts at a scrap yard of all places. I paid $10 for all 4. I placed the spray can in the picture for size comparison.
I have acquired the Mosfets and copper wire for winding the Transformers. Will update soon.
04/28/2014 at 18:44 • 0 comments -
WHAT NEEDS TO BE DONE!
03/12/2014 at 00:24 • 0 commentsBasically the only thing holding me up on this project is -
1. Some kind of cool box, cabinet or housing to put this in.
2. Winding the transformers. They are 6 turns center tapped primary and 52 turns secondary.
3. Getting the IRF1404 Mosfets, Fuses, Fast Diodes and some capacitors.
4. Working on my Radio restoration lately...
THE PCB'S
03/12/2014 at 00:10 • 0 commentsHere are the 2 pcb's I built (I was lucky and used my buddies CNC machine to make them). The reason I built 2 separate PCB'S is because the smaller one can be used for other projects ( I made 2 extra pcb's for another project). You can build all the stuff on one PCB if you like or point to point. I have the eagle files too if someone wants to have pcb's made or make the files better.
Parts is Parts (Notice my collection of EDT-49 Transformers CUE -EVIL LAUGH-)
PCB with SMPS and lm324 circuit.
PCB for 60HZ driver.
Backside view.
These are some STOUT Mosfets 100amp 500v and something like 2000 watts dissipation.
fredkono
