A collection of ideas
This is probably a really niche problem but I sometimes need an amp meter with an illuminated display when I need to characterize some LEDs from eBay that come without a datasheet, for example. In order to see when a LED starts to light up I need to turn down my lights which also prevents me from being able to read the analog amp meter seen in the project image. I could use my DMM, which has a display backlight, but using the 'built in' amp meter of this power supply is just more convenient.
From converting my broken desk lamp to LEDs I had some leftover pieces of LED strips that just seemed perfect for this purpose so I did a quick test and soldered up this prototype:
Here are a couple of links that I found useful. I'll update the list as I find new sites and please let me know if you know projects that should be listed here as well.
Let's start with HaD.io projects. A quick search results in
For the next links there's probably going to be some overlap with references from the above projects but I'd like to mention them nonetheless.
If you have googled the topic you might have come across Phil's video about the topic. There's also some more information in the video description. While on the topic of videos, this one makes a good point why a conversion might not be the best idea.
Now for some detailed tutorials over on intructables:
These are some links that might be useful for adding features like adjustable voltage and digital control:
This post about the efficieny of switching voltage regulators is also quite interesting.
For my first PSU build I used one of these cheap LED voltmeters that you can get from eBay for less than 2€. The ones I got have a measuring range of approx. 3-30V. The lower boundary is due to the fact that these meters measure their own supply voltage.
Before starting the project I did some research and found many great instructions so I'll not go into detail about the topic but rather share some pictures and comments.
Thanks! Making something more complicated than it has to be, even if it means that it's going to be more expensive, is kind of the point, isn't it ;)
That's a neat use of your multi-purpose board. Its features sound like you'd be able to build a digitally controlled power supply with it. I like a new board to play around with as much as the next guy but unfortunately I'm not really set up for PIC development. However, I appreciate the offer.
Nicely done. I have a "homemade" voltage readout based on my BOB PCB and a cheap character LCD... honestly, much more expensive and less use friendly than that cheap 7-segment unit. The BOB PCB does, however, have something on it that has potential... a high side current sense circuit and relay driver which has the (unrealized) potential to add current limiting to these PC power supplies. That could be valuable... you could set the max current, and if it is exceeded, the BOB would disconnect the supply until reset. If you are interested in playing around with it, let me know.
http://techref.massmind.org/techref/microchip/bob.htm
