The goal was to learn a little more about the esp8266 and while doing so found I left my guest WIFI port on.
Not wanting to give open access to my network I created this little project to warn me if there is an open port available.
Use an esp8266 to monitor for open wifi ports.
Would be a neat feature if it would also connect to the wifi and send the ssid to a webpage that registers the time, ssid and IP, so that with some IP adress magic you'd even get a close location.
Where you able to estimate the runtime of your battery or log the mA?
