Ta-da!
03/05/2015 at 23:06 • 0 commentsAs you can see from the gallery and the YouTube video, this is finished and working. I edited the components list to show the capacitor values I decided on.
Spitballin'
02/28/2015 at 19:47 • 0 commentsDesign circuit with the enclosure in mind.
- Inputs are LDRs, so they must be accessible to the user.
- Enclosure is metal. Must not short things together.
- Oh yeah, I have some tiny heart-shaped foam stickers. I'll poke the LDR legs through them and stick them to the top of the box.
- I can use wire insulation as leg warmers on the LDRs, since I'm running out of really skinny heat-shrink tubing.
- LDR legs must be lengthened so that the user can replace the battery without destroying the circuit.
- Okay, cool. If I wire-wrap the legs once I stick them through the lid, they'll have nice, flexible extensions to the board. Plus, I get to wire-wrap.
Find the most appealing capacitor values.
Sure, this is an extremely lo-fi synth. But it might as well be as appealing to play as possible. I have three sizes of LDRs, so it's worth experimenting with capacitors to find pleasing frequency ranges.
kristina panos
