The 1st board of rev 03 is assembled and works very well so far. SPI communication is established, the internal and on-board external temperature sensor are operational. And most important, the analog inputs and outputs seem to be happy. At least the ADC DAC settings with 0v to +10V voltage range.
With the internal voltage reference and my crappy multimeter looping back the DAC value into a ADC, I see the following results:
DAC | ADC | U[V] |
0x0000 | 0x0000 | -0.0039 |
0x0400 | 0x03FB | 2.507 |
0x0800 | 0x07FE | 5.02 |
0x0B00 | 0x0BFE | 7.52 |
0x0FFF | 0x0FE8 | 9.98 |
Looks decent, I am just not sure yet what happens at the top end of the range.
