Hackaday.io Hackaday.io
Sign up Log in
TwinTeeth: The PCB mini-factory
Diyouware TwinTeeth is a open-source PCB mini-factory targeted to the electronic hobbyists.
diyouwareDiyouware
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
7.2k views
2 comments
706 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 7
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
7.2k
2
706
53
Team (1)
  • diyouwareDiyouware
Join this project's team
  • Diyouware
  • TwinTeeth Video
  • TwinTeeth Building Tutorial
  • TwinTeeth Shop
ongoing project
drill press arduino ROBOT open source manufacturing smt delta pcb delta robot Pick & PLACE PCB LASER printer PCB ETCHING SOLDER PASTE DISPENSER
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 02/22/2015 and last updated 2 months ago.
Description
Diyouware TwinTeeth is a open-source PCB mini-factory targeted to the electronic hobbyists. It is an innovative fabricator of Arduino™ shield-size PCBs which will help you to make PCB prototypes at home.
It includes the following functionality:
- UV Laser photoengraving on sensitive film or presensitized boards using an ultraviolet laser.
- Drilling vias and holes using any mini-rotary tool like Dremel® or Proxxon®.
- Dispensing solder paste with precision on SMD PCB pads.
- Plotting circuits with a permanent pen-maker (if you prefer this method).
- 3D printing knobs, casings, front-panels, even print circuits with conductive filament, or make circuits supports.
- Milling/Carving soft materials or etching PCB copper with a v-bit (if you prefer this etching method).
And much more… because it is extendable and you can use any other tool you can fix on it.
Project Logs
Collapse
  • Making PCB vias using conductive ink
    Diyouware • 11/21/2015 at 14:49 • 0 comments
    We developed an alternative method for making PCB vias through-hole.
    There are several commercial products for making DIY PCB vias. Some based on special pins made for this purpose but they are ugly, cost money and difficult to install. Others methods are based on conductive epoxy which also is expensive and resistivity is not good.
    Electroplating is the method used by the PCB industry. There are on the internet some interesting experiences, but all of them require special equipment and unpleasant chemical products difficult to find.
    The traditional DIY method consists in threading a wire through the holes and then soldering it and then cutting it off. For example, if we have 100 vias in our PCB, we have to insert the thin wire on each hole, cut it and solder it 200 times. This is time-consuming, but also tedious, absurd, prone to failures and produces a melancholic state of mind.:-)
    So we decide to innovate in this area developing a new method which consists in drilling blind vias instead of holes and filling them with conductive ink.
    Really we don’t need holes to make vias. Well, we need holes, but not through-holes. I mean, we can avoid drilling to bottom copper layer and make tiny wells instead of vias!
    Then fill the wells injecting the conductive ink. We do it from inside, inserting a needle into the well, mainly because it will be difficult to fill it from outside due to the air inside the well and also surface tension forces.
    Both are simple task for a PCB robot.
    We published all the information in our blog:
    http://www.diyouware.com/node
  • New TwinTeeth Plus
    Diyouware • 11/10/2015 at 17:20 • 0 comments
    We just released a new model: TwinTeeth Plus
    For more information: www.diyouware.com
  • New Improvement
    Diyouware • 09/19/2015 at 13:05 • 0 comments
    We published a lead-screw improvement to the original design. We decided to reduce the size of the acme screws to reduce possible wobble and we also designed a new lead-screw top support which will hold the bearing and a bolt to adjust the motor coupler flexibility.
    You can see the new design here:
    http://www.diyouware.com/node/193
  • The tutorial is ready!
    Diyouware • 06/22/2015 at 11:41 • 0 comments
    We published last chapters of the "How to use it" tutorial.
    You will find them here http://www.diyouware.com/twth_useit in English.
    And here http://www.diyouware.com/es/twth_useit in Spanish.
    The assembling guide is also complete:
    English:
    http://www.diyouware.com/twth_buildit
    Spanish:
    http://www.diyouware.com/es/twth_buildit
  • Twinteeth building tutorial - New chapters published
    Diyouware • 05/13/2015 at 17:54 • 0 comments
    We published new chapters of the TwinTeeth building tutorial:
    Chapter 4 – Wiring the electronics
    Chapter 5 – Installing the Software
    Chapter 6 – Calibrating the robot
    Chapter 7 – Assembling the Laser ToolHead
    Chapter 8 – Assembling the Drilling Toolhead
    Chapter 9 – Assembling the Solder Paste Dispenser Toolhead
    You can find them here in English:
    and here in Spanish:
    Diyouware Team
  • New Toolhead
    Diyouware • 04/10/2015 at 12:18 • 0 comments
    We designed a new ToolHead: the microscope ToolHead.
    You can take a look it here.
    We also published more chapters in the tutorial.
  • Twinteeth building tutorial - Chapter 3 published
    Diyouware • 03/18/2015 at 10:08 • 0 comments
    We have just published a new chapter of the TwinTeeth building tutorial.
    You can find it here in English:
    Our plan is to write and publish a chapter every week.
    We will keep you informed.
    Diyouware team.
View all 7 project logs
Log In/Sign up to comment
Sign up with Github
OR
Diyouware wrote 03/26/2015 at 16:54 • point
Mainly because in that configuration the laser beam is not attached directly to the motion system. We already tested a traditional cartensian robot and we could not avoid vibrations and resonances produced by the mechanics and the belts. Also the inverted delta configuration allows us to change the tool in a question of seconds. This is very important in a multi-functional robot. We don't care too much about the Z axis lenght because the robot was mainly designed to process PCBs and 3D print small things.
suicidal.banana wrote 03/25/2015 at 15:09 • point
Love it!
Just wondering why you went for a delta approach (creating a quite tall machine) when all you really need here is X & Y? (ok ok, and rougly 2-3cm of Z) just for the fancy ascetics/because you can? or is there an idea behind it?
A modular 64Ah power bank from salvaged 18650 cells featuring USB-C (PD, QC, 18watts) to power smartphones and laptops
Project Owner Contributor
Modular 18650 power bank
jeltoJelto
Moving Ferrofluid with PCB Coils!
Ferrofluid + PCB Coils
carl-bugejaCarl Bugeja
Let's explore the New generation of PCB assembly service with JLCPCB in cheapest cost ever.
JLCPCB SMT Assembled ESP32 Development board
electroboyElectroBoy
The unique design makes its assembly independent of frames or jigs. Use hardwires to connect a pair of PCB and fold it into the shape.
Modular PCB origami
warmbitwarmbit
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "TwinTeeth: The PCB mini-factory", please tell us the reason.
Send message
Remove Member
