OK, a few days delayed, but the November code release is now available: http://speeduino.com/wiki/images/e/ee/Speeduino_Nov15.zip
It's been a quieter month as I have been simply flooded with work. There haven't been any major new features added, but I have done a lot of tweaking and performance tuning. There has also been some nice progress on the hardware side of things. So, without any more rambling, here is the list of changes in this months code:
- Ignition timing schedules have had a number of improvements. Accuracy is better and 2 bugs that could cause incorrect sparks have been fixed
- Some decoders now have faster and more accurate syncing whilst cranking
- Fixed a bug where the fuel pump would turn on if the ignition was left on with the engine off for 72 minutes
- Finalised the new v0.3.2 board. more details at: http://speeduino.com/forum/viewtopic.php?f=14&t=262
- Multiple performance optimisations
- 2nd deriv. prediction has been improved, but remains disabled. It can be enabled on a per decoder basis now.
