Hackaday.io Hackaday.io
Sign up Log in
Chicken tin toy prosthesis
3D printed foot repair
kenoraKenora
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 1
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
170
0
1
2
Team (1)
  • kenoraKenora
Join this project's team
completed project
3d printed Repair
This project is submitted for
  • Repairs You Can Print Contest
This project was created on 01/30/2018 and last updated 8 years ago.
Description
The leg of my sons chicken tin toy came off. Glueing was not an option since the area for glueing is to small. So I designed a prosthesis that can slide onto the leg. It worked with the first attempt. Maybe I will find another filament with a color more similar to the original one.
Details
Components
  • 1 × Ultimaker
Log In/Sign up to comment
Sign up with Github
OR
3D-printed blade guides for a 14" bandsaw to replace the original cast ones which were broken
Project Owner Contributor
Bandsaw Blade Guides
contemplativewoodsmanContemplativeWoodsman
This is a home made 3d printed Darth Vader helmet
Darth Vader helmet
wes1991wes1991
Avoids the risers' PCI plugs to unplug
Fixation for Bitcoins Risers' Plug
thethirdmanTheThirdMan
Steampunk themed 3D printer spool holder with gears, axles, end caps, base, and gear ratio leveraged bearings.
Steampunk Spooler
les-hallLes Hall
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Chicken tin toy prosthesis", please tell us the reason.
Send message
Remove Member
