Interstellar Emissary
Space Enthusiast + Art Installation
A real world art+science structure that seeks to provide a setting for thought and/or discussion about our place in the cosmos. And biscuits (budget permitting).
The structure's keystone is a 6ft CNC etched clear acrylic version of the famous Golden Record from the Voyager spacecraft. We are working towards having a laser track the current position of Voyager + communicate with the spacecraft (the most distant human made object in the universe). The live data will be interpreted by over a thousand RGB LEDs and audio from the record will be played thru ultrasonic speakers creating a unique experience.
Up to this point I've played the role of a artist and designer on the project as part of the Desert Wizards of Mars - A awesome group of engineers, artists, filmmakers, architects, space scientists and space enthusiasts.
Please get in touch if you are interested contributing to this on going project.
Build: April thru August of 2015
Show: BM 2015 & Sci/Educational Events
We desperately currently need ---
1)Certified Structural Designer - Input support on the Design and Materials.
2)YOU?
Inquire within...
View all 2 project logs
Rich text editor
Jasmine Brackett wrote 03/30/2015 at 16:39 point
Big Frickin Lasers! I'm very excited :)
Benchoff wrote 03/25/2015 at 19:20 point
I don't know if you actually have to track the position of Voyager. If you're only doing this for a few months, the Voyagers will be (relatively) static against the rest of the night sky.
Really, what you should be thinking of doing is shining a laser *at one point in the sky* as the Earth rotates. That's far simpler than figuring out the Voyager ephemeris etc...
Depending on your lattitude, you might not be able to see Voyager 2. Or Voyager 1. I forget. But you also have Pioneer 10 and 11. It wouldn't be too hard to put in the data for all of those.
Commotion Theory wrote 03/25/2015 at 21:37 point
Super perceptive Brian. Yep. All true. My plan was to run the clock forward on a simulator like NASA's EYES and taking a peak at if we'll be able to have line of sight on Voyager on those particular nights but knew that even if we didn't I figured we would always had a second target to point the laser at: Where Voyager is Visually OR Where it is in Reality (It's about 17 light hours away) :) As far as the live data: It would mostly be used to control the LED animations so hoping we can get that listening to DSN. Is this Brian I met at the Hackaday meetup in Pasadena?
Benchoff wrote 03/25/2015 at 23:31 point
Yep, that's me. I'll be out again in May.
You might want to check and see if the data from the DSN is actually interesting. iirc, they're down to a bit or two a second when they connect. Might be worthwhile to get some old downlink data and play that. Field trip?
Commotion Theory wrote 03/26/2015 at 03:09 point
I'm up for a field trip if possible. Email me your schedule when you get it.
Benchoff wrote 03/26/2015 at 15:48 point
After a little bit of research (this stuff is fantastically hard to find), it doesn't look like Voyager 2 is visible from most of the northern hemisphere at all. The Pioneers are on the ecliptic. 11 is somewhere around Altair, and 10 is - right now - just a little north of Venus. Voyager 1 is, I think, somewhere in Hercules.
Basically, you're looking at doing this with Pioneer 11 and Voyager 1. You can get new horizons in there too. If you're doing this in august, you'll be able to do this in the early evening until around midnight. Great viewing time.
It's an awesome project, and the hackaspace might have a shopbot to cut a huge acrylic record by summer.
Benchoff wrote 03/26/2015 at 15:50 point
Oh, one more thing. Parallax is a huge issue here. I didn't think it would be that bad, but it's at least an hour of RA for Pioneer 11
Commotion Theory wrote 03/26/2015 at 18:45 point
I'm on the floor Brian. You're amazing! Thank you for checking all that out. We're good on the disc. In fact it's on the CNC as we...type. If we go for your old data idea, we'll likely get it from the original source. We have a planetary scientist and a systems analyst on our crew - and they still work with some of the team that made Voyager 1. (Who, btw, absolutely love what we are doing)
Klaus wrote 03/24/2015 at 23:08 point
Arduino programming?
Commotion Theory wrote 03/24/2015 at 23:18 point
Currently trying to leave the hardware pretty much open to the programer's preferences. It does however need to be able to accept new/live data coming most likely from http://eyes.nasa.gov/dsn/dsn.html and reinterpret into LED animations (perhaps even sounds)
Paul Kocyla wrote 03/24/2015 at 20:59 point
How do you get the data? Will it be provided, or do you need to set up a giant dish antenna?
Commotion Theory wrote 03/24/2015 at 23:19 point
Likely from NASA's DSN (http://eyes.nasa.gov/dsn/dsn.html)
