Open source tankless water heater (hello)
I have been going over designs in my head for the past week or so and have realized, I can't draw or model very well. I can explain everything but can't do a schematic so I will (for the moment) stick with what I can do to convey what this is.
Construction:
I'm going to have a max temp of 175F set up since that seems to be standard with most water heaters I've seen so once the water in the outlet hits the programmed max or the absolute max the voltage in the coils will remain steady to keep the water heated. When there is no flow the unit will be completely shut off (in terms of heating) and I'd like to try to put the arduino into sleep mode and use an interrupt, that goes off when the flow meter starts moving, to bring the unit back up so it uses less power. The whole assembly could probably fit into a breaker box housing with little to no modification which would also help keep the cost down and make it a bit more available.
You're right but copper tubing is easy to get and work with. I can't think of another type of tubing that's ferrous and as easy to work with as copper but if you have any suggestions I'll check it out.
I was under the impression that induction heating was quite inefficient when used with copper. Most applications I have seen use a ferrous metal
