1Step 1
First, we need to upload the bin file to module
download https://github.com/will127534/7681-ATcmd
also SDK from Mediatek Labs
and connect Linkit connect module with any kind of UART to USB
with
RX <= TX
TX => RX
VCC <= 3.3V
GND <=> GND
then copy MT7681_ap_header.bin MT7681_sta_header.bin under /bin
to /Uploader in SDK.
Open a command line to /Uploader
enter mt7681_uploader.exe -f MT7681_sta_header.bin -c COMX
with COMX need to change to your com port.
you will see this after uploaded complete.
2Step 2
Second, connect module and Arduino with :
Module <=> Arduino
RX <= TX
TX => RX
VCC <= 3.3V
GND <=> GND
RST <= Any output pin
3Step 3
Last, copy all the files under Arduino Sample to your Arduino Library folder
then open Arduino IDE, select files>Samples>MT7681>connect_demo
Change ssid and key to the AP you want to connect
and RST to the Output connected to Linkit connect module.
also change constructor 7681Wifi wifi(&Serial1);
if using UNO = > change to Serial
and press Upload, then it is finished.
