Helping out Cura.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
masterofnullMasterOfNull 02/12/2018 at 05:100 Comments
Cura doesn't handle bridging very well.  If a bridged area is wider than you set your wall thickness to, it is more than happy to start printing in thin air.
However, you can still force it to get a clue with some tweaks to your model.
Cut the bottom of a bridged area into smaller long segments and make the segment width a multiple of your nozzle size.  It will then do the right thing.
This is visible here as the ribbed area in the servo pocket.
The cuts only need to be about 3 layers deep for this to work.
Similarly if you have a large flat section which doesn't attach on both ends, make it.
