More tweaks.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
masterofnullMasterOfNull 02/11/2018 at 22:250 Comments
The mirror servo was really close to the limit switch.  I moved it down and in.
Adjusted some things for better results with the required bridges.
Also reduced the size of the bearing cutouts by a tiny bit to get a press fit.
Weight is now down to 17 grams.
Printing again.
