Everything fit, but my gears for nozzle rotation didn't mesh properly.
To line things up and make the cutouts for where the servos were going to sit I had two different models. One was the actual servo model, and one was the negative I used to generate the pocket it would need. The negative one was a little oversized with exaggerated depth for the flanges and pegs to generate the screw holes. It worked well.
Well it seems over the course of the project I accidentally modified the cutout version and changed the depth from the output shaft to the mounting flanges. I've flipped the side of the flange I was going to use a couple times so I can understand how it happened..
Blue is the original, yellow is my cutout.
Depth is kinda important for a right angle drive, so now the gears don't mesh. Fixing.
