Changed my optical representation from a cone to 4:3 to match the camera and this yielded some better dimensions I could work with.
The path for the swingarm works, but I have not generated the actual part yet.
Did a little more cleanup, and it's finally ready to print.
It's only 55mm tall, but there are some bridges required which means I should probably take it easy on the print speed. I also have to dry out my nylon filament first as it's been a while since it's been used.
MasterOfNull
