1 bit full adder on fluidic elements
09/15/2022 at 13:16 • 0 commentsI assembled fully-functional 1bit full adder on 10 fluidic elements. Which doesn't require electricity for work
Fluidic-based elements can be bigger that they should be
09/04/2022 at 14:28 • 0 commentsV - means VISIBILITY. Fluidic-based element is good for scaling to both sides.
Fluidic element opensource CFD simulation
07/18/2022 at 05:42 • 0 commentsI made a setup of openfoam + CFDof + freeCAD with fluidic element and could start CFD simulation of what's happening inside and why element works incorrectly in reality. THis design was bottowed from VOLGA elements datasheet.
First 3D-printed fluidic logic element
07/04/2021 at 21:03 • 0 commentsThis is the first 3D-printed 2NOR Logic gate that works on the Coanda effect - the tendency of a fluid jet to stay attached to a convex surface.
Fluidic element prototype
01/18/2019 at 08:27 • 0 commentsMy friend Anton sent me photo of his current early-bird prototype for investigating fluidic elements.
Look brutal but it work. non-stable, but work
Fluidic logic element first simulations
10/23/2018 at 09:25 • 0 commentsBase logic element simulation results for setting to log.1 right control channel:
And left control channel:
Fluidic Logic USSR elements "Volga"
02/23/2018 at 09:59 • 0 commentsSbitardov in his comment gave me cool book that I never see before.
It's about ussr logic elements named "Volga". Quality of album is enough to reproduce the same modules with 3D printer. Let's take a loot of some elements:
OR gate with 2 positive and one negative input.
Trigger. Main differnece that it have symmetric camera. As a result - it's bistable.
AND element. 5 = (2 && 3) && !6
Other elements are here: https://www.twirpx.com/file/1603666/
This file is too large to add it here.
Fluidic kit
02/02/2018 at 09:06 • 0 commentsCuriosity led me to the Internet archive, so I found interesting kit pictures from Tekniska museet
Assume there are different logic elements in it and some additional devices for making experiments
I can't find it on ebay, but it looks so cool, so I want to find it out.![item image #1]()
I'm not sure that this is coanda effect logic. Or logic in general, but..Links:
https://archive.org/details/arkivkopia.se-digmus-tek-TEKA0008814
https://archive.org/details/arkivkopia.se-digmus-tek-TEKA0008813
https://archive.org/details/arkivkopia.se-digmus-tek-TEKA0008820
https://archive.org/details/arkivkopia.se-digmus-tek-TEKA0008816
Artem Kashkanov
