the pi has been modified to fit this project well!
ive always had an obsession with trimming the usbs down to 2 instead of 4 and used to unsolder the whole stack and resolder new single ports
With this one i decided to just trim the first port off as well as the metal cover around it leaving the top usb ports old terminals still exposed and the bottoms intact
This enabled me to run a super short micro usb cable from the pi to the touch screen controller in an effort to keep it as clean as possible
