As the title states. If you look at the photo with the black part, on the very right hand side there is a tab broken.
Couldn't find a replacement part so had to crack out the calipers and get drawing. Took quite a while to replicate in Autodesk 123 Design. Printed in bog standard PLA with 20% infill and four years on, it's still intact.
